low comp?
Old Sep 3, 2006 | 11:28 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default low comp?
car coming off road soon for repaint (thanks to brunters) while stripped gonna go efi too, is it worth going low comp too or not, thanks in advance
Old Sep 3, 2006 | 11:36 PM
reality's Avatar
reality
Depends on how much power you want..
Old Sep 3, 2006 | 11:38 PM
xr4x4rs's Avatar
xr4x4rs
if your going to rebuild the engine then yes it will proberbly be worth it
but then again you could always go teh 16v route aswell as your going efi
depends on what you want though
Old Sep 3, 2006 | 11:39 PM
se mk3 cabbie
dont wanna go too mental, about 230-250 maybe, are there pros and cons to it
Old Sep 3, 2006 | 11:41 PM
se mk3 cabbie
on bit of a budget at mo so what you guys reccomend as cheapest way of seeing that sort of power
xr4x4rs's Avatar
xr4x4rs
then it will be worth going low comp mate
theres no cons really just allows you to run more boost safely
get the rods peened and balanced along with the bottom end
head ported,cam
and the rite spec turbo you will be very happy
Old Sep 3, 2006 | 11:44 PM
se mk3 cabbie
all it has at the moment is stage 2 head, t2 cam, stage 1 turbo and double size i/cooler
Old Sep 3, 2006 | 11:48 PM
reality's Avatar
reality
You'll need low comp for 250bhp.. and your head should do it.. not the nicest cam in the world on a 1.6 but it'll work.. CVH34 is better.. you'll need a decent turbo to make that power, obviously with the right chip&injectors..
Old Sep 3, 2006 | 11:52 PM
xr4x4rs's Avatar
xr4x4rs
what efi set up are you going for aswell as this could make a difference
my advice would be cosy management
Old Sep 4, 2006 | 12:17 AM
se mk3 cabbie
not too sure yet mate, heard so many different pinions on things, is there much price difference between cossie and ofac/ofab and is cossie much better, and is it same amount of work involved in both
Old Sep 4, 2006 | 12:18 AM
se mk3 cabbie
[quote="reality"]You'll need low comp for 250bhp.. and your head should do it.. not the nicest cam in the world on a 1.6 but it'll work.. CVH34 is better.. you'll need a decent turbo to make that power, obviously with the right chip&injectors..[/quote
what injectors needed and what chip
Old Sep 4, 2006 | 12:19 AM
se mk3 cabbie
sorry lads how much do you think this can be done for
Old Sep 4, 2006 | 12:28 AM
xr4x4rs's Avatar
xr4x4rs
its hard to say on price
ofac is hard to get power out of as i dont think it can be mapped, ofab is i think can be mapped but is the most expensive out of frst
and cosy is just limitless really but proberbly the most expensive,
my last engine i done i specced for around 250 was this
low comp mahles with rings 400
head ported with manifolds to match 350
knifeedge crank 200
shot peened rods 150
all balanced inc flywheel clutch 150
cvh34 camshaft 250
then i had to buy gaskets etc, pumps so add another 200-250
bearings 100
clutch 150
in the end i sold the lot for 400 and bouht a std engine that just be reconned by ford for 550 as i wanted teh car on the road
obvioulsy i had to by turbo management etc aswell
but if you dont go efi with your head and cam and if you just rebuild the bottom end and low comp you could posibly get around 220-230 bhp
my std engine made 190 and 216lb torque, just had a chip, filter, exhaust, chargecooler
but efi is the way forward
Old Sep 4, 2006 | 12:32 AM
se mk3 cabbie
so you think i would be better keeping mfi with what i have and just go low comp, or go low comp with efi
Old Sep 4, 2006 | 12:35 AM
xr4x4rs's Avatar
xr4x4rs
depends on what you want how how much your willing to spend
with your current set up i rekon you could see 220 amybe a bit more by going low comp
but as ive said efi is the way forward
also its proberbly worth asking the person who is going to set the car up and see what he recommends as they will know more about the frst stuff
i know lee at fusion ran a good power on his and he was on ofac which ive already said is not very good but thats only what ive read and been told as he has proof of it working so proberbly worth a pm to him asking him what was incolved
Old Sep 4, 2006 | 12:37 AM
se mk3 cabbie
ok mate thamks for input anyway
Old Sep 4, 2006 | 12:42 AM
To say there are no cons is not true.
If your compression ratio is too low then you will suffer from:
poor off boost response
less top end power
worse economy
The trick is getting the CORRECT compression ratio for what you are doing.
Old Sep 4, 2006 | 12:44 AM
se mk3 cabbie
so with what i have would you low comp or not bother
Old Sep 4, 2006 | 12:49 AM
xr4x4rs's Avatar
xr4x4rs
you wont gwt thw power you want without going low comp
my ratio was 7.5.1 which is what i was recommended to go with
Old Sep 4, 2006 | 12:51 AM
se mk3 cabbie
low comp is it then, thanks, will the standard pistons (skimmed) and rods cope ok with about 230
Old Sep 4, 2006 | 12:55 AM
xr4x4rs's Avatar
xr4x4rs
well the mahles i bought new were actually std ones skimmed to give the correct ratio thsi was off them themselves
i would just get new pistons and rings that are all ready done than have yours skimmed
as there could be problems with yours you dont know about like faint fractures etc
Old Sep 4, 2006 | 12:56 AM
se mk3 cabbie
nice one, thanks again
Old Sep 4, 2006 | 08:46 AM
reality's Avatar
reality
As chip said, and to answer your question about injectors, you're best to speak to your tuner to find out what the right spec (including compression ratio) for what you're trying to do..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
