How Do I Reset My ECU?
My ECU reqs resetting but not sure how to do it and what i should be doing after to get it to operate properly.
The ECU type is EEC IV and it's on an XR2i 1.6 8v
Just disconnect your battery for a few hours, overnight if possible. Then when you reconnect take it out for a good long spin taking in plenty of different driving conditions (town and B-roads with full use of revs and gears) and avoiding too much cruising at constants.
Thanx very much for the replies.
One more question tho, how long should idrive it for before it should all be set up?
30mins? 1hr?
30mins? 1hr?
No disrespect chaps but disconnecting the battery will do fuck all !
Phil you need to remove the KAM fuse on top of the fuse box its a yellow 20 amp bugger for 30 mins
KAM = Keep Alive Memory
Pull that bugger out and it will reset the ECU
Then you need to start allow to idle for 20 mins so it learns its new values then go for a drive should sort it
Regards Doug .
Regards Doug .
Ok, couldn't find that fuse. the only fuses i have are my ordinary fuses on the front and a load of relays on the top.
So i disconnected the battery and unplugged the ECU. I'll leave it for 30mins still tho
'If the battery has been disconnected these vehicles may exhibit some unusual driving characteristics for approximately 5 miles (8km) after battery reconnection.
This is due to the automatic relearning of the engine management system to the actual engine and may be disregarded.'
Regards Doug . [/b]
Doug.. considering the eec-iv doesn't have a battery in it for any "keepalive memory".. how do you explain that removing the battery doesn't have the same affect as removing a fuse?
Leaving for holiday flight soon, so appologise for not replying to this thead further.
Originally Posted by woodz77
out of interest cos im thick why and how did you know you had to reset your ecu ???
I had to update my idle valve and had to update my ecu with it.
When i plugged it in and started it up, the engine was still really warm so it set itself up, and when i started it from cold the next morning it didn't want to idle til it had warmed up.
I also had another problem i needed to sort out as well which i didn't notice so i'm gonna have to do it again now so it reads the correct values
So that it learns the correct values so it runs properly.
The air flow was restricted before and now i've sorted it's not idling properly co it's getting more air now than when it was when it was going thru its setup
Regards Doug .
Regards Doug .
2nd I think that Stu has basically seconded what I was saying so no sueing Ford today lol
Regards Doug .
Still interested in where this fuse thing could be tho?
Not doubting u or anything, just couldn't see it for lookin.
Even took the fuse box out from underneath the dashboard to look for it
DixieTheKid
14-09-2015 09:04 PM
4347, advtanges, battery, disconnect, ecu, eeciv, escort, fiesta, ford, motorcycle, peugeot, properly, relearning, reset, resetting
