Cossie engine loom v Twin cam engine loom
Ok i have been sorting out the wiring on my 2wd cossie loom and have hit a problem where the main loom links into the engine loom
I HAVE REMOVED THE STANDARD COSSIE WIRING LOOM AND IM USING A TWIN CAM LOOM
Ok on the cossie engine loom has these colours;
Black/Red, Black, Empty
Blue/Red, Empty, Empty,
Empty, Brown/White, Green .
On the Twin Cam loom has these colours;
Brown/White, Black, Green/Brown,
Red/Blue, Blue x2 wire, Empty,
Black, Brown/White, Green.
Should i just rewire the plug as i have a brandnew loom to fit for the engine side i know whot the colours are for on the cossie plug but not sure on whot some of them on the Twin cam loom are for
Can anyone help CheeRS
Black/Red fuel pump
Black switch ign
Empty
Blue/Red 12v+
Empty
Empty
Empty
Brown/White water temp gauge
Green rev counter
Brown/White poss water temp
Black switch ign
Green/Brown oil light
Red/Blue 12v+
Blue x2 wire batt light
Empty
Black switch ign
Green rev counter
the twin cam loom has the batt light built into it with teh batt power cable as a cosy has it seperatly
the 2 temp gauge wires ( brown/white) then you will just have to find out whic one is what
other than that its straight forward bar one connects behind batt and the other behind dash
im a bit lost of what your trying to do
Black/Red fuel pump
Black switch ign
Empty
Blue/Red 12v+
Empty
Empty
Empty
Green rev counter
Black switch ign
Red/Blue 12v+
Empty
Black switch ign
Green rev counter
Originally Posted by DanCossie
seems like alot of effort for nothin??
what you tryin to do matey??
The Standard cossie loom has the light computer ect and stereo amp on the loom and i dont want any of that Crap
xr4x4rs the twin cam loom has the batt light built into it with the batt power cable as a cosy has it seperatly
Ok that makes sence as i was looking in the engine bay for the plug on the twin cam loom that links up with the cosworth engine loom Only to find it inside the car with a load of other wire
Ok im now ever confussed i have been over to the car and had a look @ the loom and now im total lost
I've got 2 plugs and it looks like theres some wire in both plugs That the cossie just use in the one plug then theres the others i donr have a clue whot they go to HELP NEEDED
Ok xr4x4rs Has said whot these are for on this plug
Then there this Plug which has
RED/BLUE, (Smaller) RED/BLUE, RED
BLACK/RED, GREEN/BROWN, BLACK
Then theres ths Small Round Plug
BROWN/YELLOW,
BLACK/RED, GREEN/BLACK,
And theres also a ODD 1 Biggish cable tho (think it was BLUE/RED)
And can someone tell me whot the wire are for on the PLUG that goes to the Speedo Unit (Please )
- GREY/GREEN
-BROWN
-BLUE
-BROWN/YELLOW x2
-BLACK/GREEN
-BROWN/BLACK
-BROWN/WHITE
-GREEN x2
-BLACK/WHITE
-BROWN/GREEN
-BLACK/YELLOW
-BLUE/WHITE
God i HATE WIRING
Any help i need to sus this asap hope to get it sorted this wkend so i can do some other bits
BROWN/YELLOW,
- GREY/GREEN
-BROWN
-BLUE
-BROWN/YELLOW x2
-BLACK/GREEN
-BROWN/BLACK
-BROWN/WHITE
-GREEN x2
-BLACK/WHITE
-BROWN/GREEN
-BLACK/YELLOW
-BLUE/WHITE
God i HATE WIRING
Re: Cossie engine loom v Twin cam engine loom
Black/Green, (it has green strip on it i missed) Brown/White, Green.
Originally Posted by Ryan
just give me a call
07919537128
have a pen and paper handy
i cant be fooked to type it all out.
07919537128
I will owe you a Beer or 2 @ some point if you can clear up this big mess of wires i have atm I'll be fine when i know whots whot ect just dont know where to start
muz
16-08-2015 12:57 PM
