Need Help/Advice.... poxy car!!
Right, I must have taken the car to the worlds strictist MOT man.. Now I appreciate he justs doing his job etc.. at least I no its all ok..
Except for these poxy emissions..
This is the problem.. to turn the CO down you need to adjust the screw I believe (its a allen key job).. Well, apparently someone has used a flat head on it, and its a little fooked What can I do
Any advise appreciated before I just leave it in the local council estate and let them joy ride the fooker
Originally Posted by ballin
bit unlucky to get CO tested!
if you cant turn it then dunno!
You need to find a FRIENDLY MOT station Westy! Makes all the difference when it comes to bollocks like this!
1 Post
The MOT gaf I took mine too said that they couldn't adjust the screw to turn it down. A quick trip to see Chris Todd @ Power Engineering and it was all sorted within 2 mins and it was all sorted
Metering unit change could be the only option if it's threaded it
Not in Beds Westy, but i might no someone who'll do it for you in Stevenage...
Might cost you a drink on top! Wink Wink Nudge Nudge!
Ps if its a tub he wont pass it END OF. but if thats the ONLY THING its failing on.......... No worries!
same thing happened to my old red one, poxy screw was knackered, in the end the MOT'r waved the sensor around the back of the car and click accept quick when it was in limits
He does mine as well.............
steerfromdarear
28
29-01-2016 06:14 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
