ROVER GEARBOX ADVICE.........
Hi guys ive got a 147k s/history rover 400 sdi 2.0 turbo diesel and the gearbox makes a slight rumbling sound but dissapears when the clutch is pushed in...ive been told it could be the thrust bearing???, ive had the car for 8 months and ive done 18k miles and the sound has always been there and hasnt got any worse, is the gearbox totally fooked or jst worn wear and ok to keep driving??? cheers all
aint that bad mate the car is a good daily drive for me very reliable, economical, and cheap to service and insure! would just like some simple advice , cheers mate
I'm only playing
If you can hear a rattling noise and it dissapears when the clutch is depressed, its just the thrust bearing rattling around on the shaft.
Ive heard new cars do it. My cabby has had a clutch in and its done 3.5k, and has annoyingly enough done it from day one
Its usually nothing to worry about, just annoying to hear
cheers mate i bought a spare 26k mile gearbox to go in when it goes only cost me £50!!!, gona get it fitted whn (if) the clutch needs replacing as ive been quoted £205 to supply and fit new clutch and change gearbox inc gearbox oil change
Originally Posted by NUTS RuS
If you have a spare why you worrying
Problem sounds like its not even inside the box - unless its a bearing.
Can't you drive everywhere with your foot pressing the clutch down all the time so its quiet
its not the fact ive got a spare box sitting in the garage, if the problem is not box destroying bad then ill leave it til the clutch goes and then fit it. cheers for the replies
i think its the gearbox layshaft bearing...
thrust would normally rumble/squeal when pressing clutch.
its just a worn box, but if you have a spare, dont worry... could take months before it goes completely...
HTH
HTH
chowfornow
14
05-01-2019 09:01 PM
