Secs data
Old Jun 12, 2006 | 11:53 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default Secs data
so i fitted the secs monitor.... great product
What would you guys say was a good act? mine is steady at 30 degrees on a cruise , what difference would water injection make?
And the map reading is different to my shonky boost gauge, so i take it i should adjust the boost to the map reading and ignore the gauge...
Old Jun 12, 2006 | 12:25 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
ACTs on a light cruise are TOTALLY AND UTTERLY IRRELEVANT . Go see what it is on full chat .
However, if it exceeds 60+°C (back off straight away), you need to think about WI and/or a better intercooler .
Who-ever live mapped the car would have done so connected to the ECU, so would have mapped it to the boost pressures the car was seeing NOT a shonky aftermarket boost gauge .
Old Jun 12, 2006 | 12:30 PM
JTECH James
Passion for Fords!
its got a 50mm pace rs500 style cooler
and i wish it had been live mapped but i live in devon you know
Old Jun 12, 2006 | 12:34 PM
RS500/364's Avatar
RS500/364
it is alway worth the drive why do you think pepole bring there cars from holland and far to have done!!!
Old Jun 12, 2006 | 12:36 PM
JTECH James
Passion for Fords!
it will be done! its only stage 3....
Old Jun 12, 2006 | 12:57 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I'm trailering mine to MSD Where abouts in Devon are you ??
Old Jun 12, 2006 | 12:58 PM
Mike Rainbird
Caraholic
These intercoolers are "okay" up to 25psi, then the ACTs climb sky-high.....
WI will be a must on your car if you exceed 25psi.
Old Jun 12, 2006 | 01:00 PM
JTECH James
Passion for Fords!
im in totnes.....
mike thanks mate, im peaking at 25psi, but i will fit the rest of the water injection asap , what sort of drop will it give?
Old Jun 12, 2006 | 01:03 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Sorry to post-jack but is it ok to use just the SECS monitor outputs to control the WI Mike ???
ECU Monitor Enthusiast
Default Re: Secs data
Thank you
Old Jun 12, 2006 | 01:09 PM
Mike Rainbird
Caraholic
Yes it is .
Best to set temp to be "ON if ACTS exceed 42°C and boost is above 10psi". This is the rally strategy and keeps the ACTs around the 44°C mark at full chat (with WI running).
Old Jun 12, 2006 | 01:15 PM
JTECH James
Passion for Fords!
you need to run the WI pump through a relay i think not directly from the secs unit
Old Jun 12, 2006 | 01:18 PM
Mike Rainbird
Caraholic
Yep, obviously you need to wire up the pump as per the SECS instructions, I just thought he meant could he use the SECS instead of using the ECU to control it (which it can with Pectel hardware).
Old Jun 12, 2006 | 01:19 PM
JTECH James
Passion for Fords!
Old Jun 12, 2006 | 01:41 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Thats what i meant
Old Jun 12, 2006 | 01:42 PM
JTECH James
Passion for Fords!
all good then
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
pabloXR
Sep 21, 2015 12:42 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
