Help with bad running engine please
Old Jun 11, 2006 | 09:19 PM
B16's Avatar
B16
Default Help with bad running engine please
My sister has a P reg escort cab ghia 1.8. When it is being driven the revs stick at 2 thousand and start to hunt, but only when it is being driven not from standing when you rev it. Any ideas anyone please.
Old Jun 11, 2006 | 09:20 PM
digita1dragon's Avatar
digita1dragon
Sounds like the ISCV (Idle Speed Control Valve) apparently you can remove them and clean them. Never done it myself tho.
Old Jun 11, 2006 | 09:23 PM
B16's Avatar
B16
Hiya Can you tell me where this part is and what it looks like if poss.
Old Jun 11, 2006 | 09:51 PM
digita1dragon
Its just under the throttle body, 3 small bolts hold the cover on
HTH
Old Jun 11, 2006 | 11:13 PM
B16's Avatar
B16
Thanks for info i will give it a try.
Old Jun 11, 2006 | 11:18 PM
MK5RST's Avatar
MK5RST
Squirt it with air intake cleaner/carb cleaner then a bit of wd40 and carefully move the plunger back and forth then disconnect the battery for 30 mins and put the idle control vavle back on then reconnect the battery, start the car and allow it to idle for a few minutes
Old Jun 12, 2006 | 01:30 AM
B16's Avatar
B16
Thanks, see how I get on tomorrow
Old Jun 12, 2006 | 02:04 PM
B16's Avatar
B16
If you tap the Idle control valve should the revs rise at all.
Old Jun 12, 2006 | 05:39 PM
B16's Avatar
B16
Idle Speed Control Valve was the problem. Thanks for replies. Paul
JoeyBoyden
Jan 4, 2024 02:36 PM
Chas
Sep 21, 2015 08:57 PM
Roosie
Aug 13, 2015 07:40 PM
Zoggon
Aug 10, 2015 10:39 AM
ginger1979
Jul 31, 2015 09:56 PM
