T56 geaboxes- different ratios- from which car?
DEYTUKURJERBS
Theres three T56 box ratios, inc one with a mega long 0.5 6th gear (the other 2 have .62 ratio 6ths).
What car is that super long one off?
Anyone know? Marco? Sheady? Bernie?
K155MYRS
Steve does this help.
Model T56-Viper
1st 2.66 2nd 1.78 3rd 1.30 4th 1.00 5th .74 6th .50 650HP 600 ft/lbs.
Got the info from here I'm guessing that's the viper one?
http://keislerauto.com/gm/transmissions/builder2.asp
and here..
http://www.need-4-speed.com/tremec.htm
Model T56-Viper
and here..
Originally Posted by Cam
The Corvette T56 had the tall top as a option plus has the best [triple cone] syncromesh
Std Viper gear ratio's are
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th 0.74
6th 0.50
Final drive of 3.07
Rear tyre size of 335/30/18
Thats for the new gen 3 - 500bhp srt10 engine
You can get the t56 direct from ford.
# This is the same Tremec HD 6-speed manual transmission used in the 2000 Cobra “R” and the Ford Racing FR500 Mustang
# Fits 4.6L SOHC/DOHC engines
# Can be used in 1999-04 Mustangs and Cobras
# May require shorter driveshaft, modified crossmember/trans mount and other minor modifications
# 440 lbs./ft. torque capacity
# Gear ratios: 2.97/1st, 2.07/2nd, 1.43/3rd, 1.00/4th, .80/5th, .62/6th
# Does not have mechanical speedometer connection needed for use in earlier Mustangs
# 10 spline input, 31 spline output
You can get a mech speedo one also
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th 0.74
6th 0.50
Final drive of 3.07
steerfromdarear
28
29-01-2016 06:14 PM
