Help needed ...( DESPERATALY )......Please
Right for the last few weeks my car has been running worse when on boost so i took the plugs out 2day and there are black.........especially number 2 pot so i decided to take the injectors out to try and see why pot 2 was always worse and what i found was the person who had had the grays before had cut open the hols in the little plastic caps and number 2 was cut right open as you can see by the pic...................Right what i need to know is i have a set of blue injectors with caps on that i am going to put onto the grays but i need to know if the hole in the plastic cap is bigger on grays???????? if so dose any1 know about what size the hole is....................i also have a set of dark greens and the hole looks about the same size...........................Thankyou in advance hope somone can help............
Right put them back in and i think i found the problem, took the car round the block to check it and my boost normaly peaks at 30ppsi then drops right of to about 23psi......not now put me foot down in 4th and it went round to about 35psi before i noticed and lifted off before i done any damage so i went home and turned the boost back down to what it was after a few runs down the road till i got it right and now the boost does not drop off as much so i have had a boost leak all this time
Next question what boost can i safely run on grays?????? car revs to about 7500rpm just in case this helps
was only setup a few month back but he did not turn the boost up past 30psi as he said the turbo was ringing its neck but it seems this has been due to the leak......but on the day we checked all the pipes and manifold and could not find any leaks, don't even know were it was leaking as i have only had the plugs and injectors out...
Originally Posted by Stu @ M Developments
This haphazzard meddling is going to end in tears!!
Stu also while i am talking to you i am changing the turbo on my car it is a 2wd saff thinking of putting a gt32 on it as i can get hold of one at a resonable price..........after i get it and get it fitted i would like to take it to you...... i was wanting a price on supply and fit some siemans injectors and setting the car up ( live map ) and also do a closed loop conversion for me please..( I understand i will need a l8 ecu for this ).....if you could pm me a rough price also i would appreciate your comments on the gt32 turbo before i buy it....................thankyou
borboyous
22-08-2015 11:17 AM
