C20LET Pistons - Compression?
I have used the N/A forged XE pistons in my ZT and have a CR of 8.1:1 if that is any help.
Most of the extra chamber volume is acieved by a lower deck height on the pistons. Not ideal but it will work for what i want from that lump.
Originally Posted by The Usual Suspect
whats the diffs between high comp and low chipper? i thinks its lower the more boost you can safely run?
Basically its all about managing peak cylinder pressures.
If you run lots of boost and lots of CR, then cylinder pressure sky rocket and you risk detonation, to combat this you have to retard the timing and that then loses you power.
Its very application specific though, if you are using 108ron fuel you can run high boost and high CR at the same time easily.
Also at higher RPM, because the cylinders fill less effeciently, you can run more boost without needing to lower the CR.
My own LET engine im building is very much like that, 8.2:1 compression and 8500rpm
Where as a cossie tuner going for 500bhp would normally use 7.2:1 and a lower rpm range.
These days i wouldn't even bother with the XE/LET pistons as you have to mod the rods as well. I would just get another custom set from the states.
cheers for that chip all is clear now
garage19 what mods do you speak of? i have farndon steel rods arp rod bolts and c20lets not aware of any modding
Depends if your rods were bespoke made for those pistons or are just of the shelf zetec items? They will aready be designed for a fully floatng gudgeon pin but you may need to get the little ends reamed out a few thou to fit the slightly larger LET gudgeon pin.
deathrider666
Sep 28, 2015 06:12 PM
budget, c20let, compresion, compression, cylinder, height, high, kompression, piston, pistons, recommended, standard, stock, turbo, zetec
