TOTB 5 press release :D
#41
Originally Posted by staffi
Kieth, how do you think you will fair on the handling circuit? is it tough with all that power
not going to be good with no p/s
Keith
#42
Keith
i am guessing that is because you dont want the power steering pump running off the engine if that is the case can you not just fit a electric power steering pump to run the power steering when you chose ie. handling circuit ?????
#43
Anything different on the car for this year Kieth?
It is now a 3L engine with a big single that will run 1250 bhp
we should be up another 200bhp from last year.
Keith
Team Cowie Drag GTR 2006 NEW SPEC
SPECIFICATION
ENGINE
Nissan Skyline GT-R R32,3L OS Giken motor, uprated Tomei oil pump, RB
Motorsport big sump and Trust remote oil filter kit, RB Motorsport modified
oil feed to cylinder head, Mocal oil cooler,RB Motorsport cylinder head Oil
Scavenge Pump system,Turbo Dynamics 1250 bhp GT spec single turbo,Trust
racing wastegate and short dump pipe, Trust RSPL-R 170mm-thick cored
intercooler, RB Motorsport custom hard pipe kit, Trust racing dump valve,
R.B Motorsport 110mm throttle body, R.B Motorsport ultra-large plenum, HKS
300+ degree Step 3 PRO L camshafts, OS Giken 3L adjustable cam pulleys,
Tomei kevlar-reinforced timing belt, Tomei valve springs and retainers, RB
Motorsport-spec modified cylinder head with 1.5mm Oversize IN /EX valves,
Trust 1.2mm head gasket, RB Motorsport fuel rail, 1600cc injectors, New
Bosch 044 external fuel pump system,uprated fuel pressure regulator,
12-litre alloy fuel cell, Trust OS 3L exhaust manifold, RB
Motorsport-modified 5" exhaust system, Trust uprated radiator, RB Motorsport
modified cylinder head cooling system, Autronic SM4 engine management unit,
Autronic 500R High power Direct Fire ignition CDI unit 605 Volts, large
Autronic boost solenoid, six Bosch single-plug coils
Power Output expect 1200bhp, but will never be dyno'd to find out.
TRANSMISSION
All OS Giken unless otherwise stated: four-plate clutch assembly, OS-88
six-speed sequential-shift gearbox with custom-made RB Motorsport-spec
gear-cluster, OS Giken Super Lock limited-slip diffs front and rear, Nissan
transfer box, Nissan drive shafts all through, RB Motorsport Flat Shift
gear-lever kit,Torqline 5.9 kg carbon propshaft.
BRAKES
DBA Skyline GT-R discs and calipers all round
SUSPENSION
HKS Hypermax Drag system all round,Everything adjustable, RB
Motorsport-reinforced rear beam assembly, uprated bushes throughout.
WHEELS/TYRES
Mickey Thompson ET drag radials all round, 26x10.5x16in fitted to standard
Skyline R32 GT-R 8x16in five-spoke rims
EXTERIOR MODS
Radical lightening programme, glass fibre replica doors with plexiglass
windows, VeilSide Drag boot lid with integral low-line rear spoiler,Simpson
Parachute
INTERIOR MODS
Totally stripped-out interior, Bride racing driver's seat, standard R32 GT-R
steering wheel, custom instrument layout with oversized boost gauge and
gearchange light, safety cage,
RB Motorsport mechanical 4wd controller.
Proper bonkers that mate.
Btw I hope to be spectating totb.
#45
Originally Posted by MADRod
Will yours be at the event then Rod?
But you are still young at heart.
Keith
#49
hI
Personally i dont want the stress an event like this brings, last year spent 4k to prepare the car & it lasted 5secs, that aggro is not required at 60 with my blood pressure.
My car is not suited for this event in any way. Topspeed wise could probably be very competative & i await to see how many are past 200mph at the mile. But ive consentrated on Topspeed & that takes 1.5 miles so im not really interested in my speed at a mile. The quarter mile aint for full weight road cars & mine would struggle to get in the 10's & ive no intention of changing the car to suit the drag strip. Handling ive no idea ive all the right bits but way to heavy, ive got more sound proofing in mine that Keiths car weighs . .
Fudgey
17-09-2015 01:06 PM
The Enigma
12-09-2015 10:12 PM
