PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   General Car Related Discussion. (https://passionford.com/forum/general-car-related-discussion-12/)
-   -   Tim's ERST (https://passionford.com/forum/general-car-related-discussion/101086-tims-erst.html)
Karl Feb 9, 2006 11:48 AM
Tim's ERST
Following on from the PE rr day we ran up the car again at Nobles yesterday. As you can see from the torque curve things are VERY different to the PE results!
Now at PE we ran 22 psi as opposed to 27psi at Nobles but this still shows the huge difference in top end torque!!
https://i15.photobucket.com/albums/a...ms/TimPErr.jpg
https://i15.photobucket.com/albums/a.../Tim308rrb.jpg
Rudey Feb 9, 2006 11:51 AM
we all know how inacurate rr,s can be, i dont think you or tim have anything to prove tbh
RichardPON Feb 9, 2006 11:51 AM
What does it rev to?! :eek:
Power just looks to be climbing and climbing!
JohnnyB Feb 9, 2006 11:53 AM
yes the power is still climbing after 6000k
but looks the same
Rick Feb 9, 2006 11:56 AM
:top: :top:
What cam's she on? Still hydraulics?
Even Linsays graph tailed off on the power rollers compared to nobles.
Rudey Feb 9, 2006 11:57 AM
why not run the same boost though if a comparison?
gingeRS Feb 9, 2006 11:58 AM
20 bhp for 5psi!!!
i'd get more than that if i upped mine by 5psi
:blabla:
dumped Feb 9, 2006 12:00 PM
So how can you choose one to trust :cry: :cry:
Rudey Feb 9, 2006 12:03 PM
:cry: :cry:
Tim Feb 9, 2006 12:04 PM
With the boost the car has 23 psi to 6000 then every 5oo rpm it rise to 28 at limiter,just shows there wasnt enough air flow for MY car @ Powers.
Rick Feb 9, 2006 12:06 PM
Does that mean she runs 23pis from say 4k to 6k, THEN it rises?
Karl Feb 9, 2006 12:06 PM
Martin exactly you can't comapare RR's.
The thing is though you can tell from the fuel map where a car makes peak torque, because peak torque happens to co-incide with peak VE and hence this is shown by the fuel map. Tim's peak torque is 6500rpm.
I just thought it rather interesting to show that the results from PE show the torque falling after 5500rpm.
With regards to rpm Tim's usual rev limit is around 7300rpm and it makes peak power at around 7000rpm.
At a later date I will post a complete run through to the limiter but for now thought Id show the difference at the same rpms between different RR's.
(This is not a dig btw simply a post to show how RR's do vary and that you cannot trust them as reliable info)
Karl Feb 9, 2006 12:07 PM
Yes Rick.
DanS Feb 9, 2006 12:23 PM
Tim are you running at bedford? ;)
Mike Rainbird Feb 9, 2006 12:27 PM
It would have been better to show this at the same boost level - surely :p?
Rick Feb 9, 2006 12:27 PM
Karl, that a turbo gradually building the boost issue, or is it mapped like that - perhaps for traction? Either way - im lovin it :top:
Tim Feb 9, 2006 12:28 PM
it is the same boost up to 6000 read above lad keep up lol
:cry: :cry: :cry: :cry: :cry: :cry:
Rudey Feb 9, 2006 12:29 PM
get it on the track fook the rollers :top:
dumped Feb 9, 2006 12:33 PM
I believed most of them made their power higher as they all pulled monster speeds without outragous gearing :D:D:D
I still think accel runs , loaded or not are dubious as you change the figures just by changing run rates etc.... I'm my head static load it and record BRAKED HP. But people dont like this as equiptment costs more to be reliable - temps are harder to control - takes longer.
Another problem on RR days are people sometimes dont take the time to set the wheels speeds accurately in the rush to run many cars - have seen this on many rolling road days over the country.
bud-weis Feb 9, 2006 12:35 PM
So basically at PE rollers the car couldn't do what it was mapped to do, i.e hold 23psi to 6k and then rise to 28Psi
because of the temps the ignition was being retarded i think you said before??
good graph :top:
Rudey Feb 9, 2006 12:35 PM
tim have you drag raced christian yet?
AlexF Feb 9, 2006 12:44 PM
surely they didnt go to Nobles for the purpose of doing a pe....
maybe theres a reason why the boost was different and that was why it was run on a RR
:top:
Steven_RW Feb 9, 2006 12:57 PM
I mapped out an excel spreadsheet with the two bhp curves. It looks like the rollers are 500 rpm lower on PE than on Nobels. What I mean is, when I put a 500 rpm reduction onto the nobels rollers the graph lines up very nicely with the pe one and vice versa.
RW
Neil S Feb 9, 2006 01:14 PM
Stevie, does that not confirm what martin is saying?
i.e. the revs are back-calculated from wheel speed?
Jon ERST S2 Feb 9, 2006 01:16 PM
he already said.. the boost rises at a set RPM. So it wasn't running any more boost! It runs more boost higher in the RPM and would have at PE if the revs would have gone high enough.
:top:
Steven_RW Feb 9, 2006 01:22 PM
Neil S
Yeah, it would confirm that RPM are generated back from wheelspeed. However it sounds like rollers were set for a car that had larger wheels/gearing and they didnt reset it for Tims car.
As said, the graphs are pretty much identical until the final few RPM where on the nobels graph it rises.
I am also wondering why people run different boost on different days?
RW
Jon ERST S2 Feb 9, 2006 02:14 PM
No need to wonder just read :p
RW
JamesH Feb 9, 2006 02:18 PM
:top: :top: :top: :top: Brilliant!
Mike Rainbird Feb 9, 2006 02:39 PM
To all those people commenting on my query regarding the boost situation....
As Christian hit his limiter (set at 7+k), but registered significantly less :p.
It's Czech Mate Feb 9, 2006 02:43 PM
Have I got this wrong
Everyone seems to say that the rollers under read his rpm and he actually pulled the 7k+ rev limit. Well if this was the case would he not have hit the 28psi boost? Or is the fact he didnt hit the high boost down to the Fan size and ACTs?
Rick Feb 9, 2006 02:44 PM
So basically, we don;t know what the true RPM was at PE.
Steven_RW Feb 9, 2006 03:14 PM
Rick Correct,
From the graps I made with a lag of 500 rpm, the car hit roughly its correct rpm I a was also told the car was running less boost so my comment still stands.
RW
Sexy-RS Feb 9, 2006 03:20 PM
My car doesn't like rolling roads it goes bang at 5k lol on them, but never does this on the road :cry:
Mike Rainbird Feb 9, 2006 03:30 PM
Correct :). Christian stated in the RR post though, that he hit his limiter....
Karl Feb 9, 2006 03:51 PM
Rick the car is mapped so that the boost increases as rpm does, as this aids traction by bringing the boost in progressively.
It's Czech Mate Feb 9, 2006 03:56 PM
SO if the PE rollers were under reading rpm, and Tim pulled his limiter, why did he not hit 28psi boost? Is this due to the fans/poor act?
lmans123 Feb 9, 2006 03:59 PM
:top:
Tim Feb 9, 2006 04:16 PM
no it never hit the limiter and the peak recal on the defi was 1.5 not bar about 23 psi
DaveEscos Feb 9, 2006 04:18 PM
PE rollers under read
PE roller over read
make your fucking minds up tards!!! :cry:
It's Czech Mate Feb 9, 2006 04:20 PM
:top: Cheers
© 2026 MH Sub I, LLC dba Internet Brands
