Fuel rail AN fittings
Anyone running AN fittings on there fuel rail my question is what pressure regulators are you using and where have you located it only regulatord I can find are ones that actually fit in the rail pics would be great many thanks |
I had fittings brazed onto my standard rail. One iver end and one in the middle. Mine has a kinzler reg that’s mounted on the inner wing oppersite the inlet manifold. |
Originally Posted by ajamesc
(Post 6783439)
I had fittings brazed onto my standard rail. One iver end and one in the middle. Mine has a kinzler reg that’s mounted on the inner wing oppersite the inlet manifold. think this is what I’m going to do but hear the pressure can fluctuate of away from the rail how was yours |
I bought a billet Fuel Rail (engraved Cosworth) and got him to add the AN fittings, I also bought a billet FPR housing and Jenvey regulator. The Jenvey is adjustable and Mark Shead recommended it.
(Post 6783445)
im interested in doing mine this way |
I'm running a billet fuel rail from MK Motorsport with an fittings to a Turbosmart FPR 800 which I mounted in the n/s inner wing. Once I work out how to post the pics up I will do so. |
Originally Posted by timsrs
(Post 6783514)
if you could post some pics please im interested in doing mine this way You will have to excuse MK's hands in the pic as he was asking me where I wanted the fuel pressure sensor. This is the billet rail before it was coloured black. I had Cosworth engraved in it. You can see the billet fuel pressure reg housing on the end. The little threaded holes are so it can attach to my Hart inlet manifold. |
https://cimg1.ibsrv.net/gimg/passion...a226bc350f.jpg
Here is one on 800bhp's engine. I like the engraving on this. |
Originally Posted by cossie51
(Post 6783516)
I'm running a billet fuel rail from MK Motorsport with an fittings to a Turbosmart FPR 800 which I mounted in the n/s inner wing. Once I work out how to post the pics up I will do so. https://cimg1.ibsrv.net/gimg/passion...aa9b6ef5c.jpeg To upload a pic just hit that icon and browse your pics |
I added 6an fittings to my fuel rail and placed my regulator just ahead of the oem hard line outlets, just below the coolant tank. In the picture with the black cam cover you can see the regualator with the green paint dot on it. Hope this helps. It's actually pretty simple once you start on it. I used olive fittings to put 6an male fittings on the oem hard lines.
https://cimg9.ibsrv.net/gimg/passion...5fa691d877.jpg https://cimg1.ibsrv.net/gimg/passion...59bc71ff32.jpg |
Great brilliant pics cheers |
https://cimg4.ibsrv.net/gimg/passion...d343715aec.jpg Mounted mine on the inner wing. |
© 2024 MH Sub I, LLC dba Internet Brands
