Deatschwerks fuel pumps
Has anyone used these
thinking of using one for my 600bhp build
goin to have standard Cosworth pump feeding swirl pot
then this pump feeding rail
they say the flow 350lph
044 flows 200lph
so seen better than running two 044’s
044 flows 200lph
Who's mapping it mate? I'd go with what they say I bought an aeromotive a1000 pump set up probably not going to use it and go with tuners recommendation
good pump then Mark ?
The 350 in line pump says it can supply for 750bhp
Mark my plans are....
standard Cosworth pump supplying swirl pot ( under car )
I have an aftermarket tank and want to eliminate any possible surging
Then the DW pump suppling the rail
cheers
what sort of setup have you done Mark
cheers
I m going to run the DW based on mr Sheads advice but mine will be gravity fed by a simple sump in the car floor so all fuel drains to that point. The standard pumps can be quite noisy in the car.
Alex_86
16-06-2008 03:37 PM
Turbo Zetec
24-12-2006 02:57 PM
