Headlight wash / wipe
Interesting Post.
If i may add to it?
I want to add the headlight wipers to my non cossie sapph. I have the wiper motors.
What else is needed?
Does it run off the same circuit as the main wipers? I assume it needs a special relay with fuse etc?
Can it be easily done?
If i may add to it?
Here is the wiring diagram. Not sure off hand the difference of each page but it is usually High spec, low spec, left and right hand drive. Will probably be able to confirm when I have been home but shouldn't make much difference for what you want.
David
David
Bren1977 (09-04-2021)
rich.edrsoc
14
09-12-2008 11:15 AM
Christian and Beccy
37
07-10-2004 04:53 PM
