Diff breather
Diff breather
I took the old nail for an mot last weekend, came away with a pass but noticed whilst it was on the ramp that there is a small oil leak from the top of the diff.
Assume it's just the breather? Are these just a small length of hose? I've not had a chance to properly look yet
Yes, may need to check the oil level but sounds all ok, why not change the diff oil anyway, pop the back off and inspect and refill.
Just sealant, I used instant gasket from Halfords. I believe the diffs can wear and lose some of their locking on the lsd. Make sure you use lsd oil. (LS on the bottle) and it stinks when you take it out so lay down old rags to soak up any spills.
Bara told me that I MUST use LS oil in my diffs (admittedly I have a Quaife front and Weir Supra rear now)
I know that some transmission specialists can change the fluid on the viscous LSD and also increase the locking of them. But it is not something you can do at home. Or at least I've never heard of anyone doing it. This is all just for the standard Ford viscous LSD, any other LSD can be different of course.
Toby
I've got some 75w90 at home, was just going to use that?
PF Idiot Sniper
I just found this via google because I have the same issue on my 3dr. The drip is driving me insane. I had the oil changed and 500 ml came out and 1 litre went back in. But it vents out the top pipe.
1 it's making a mess of my garage but 2 it causes real issues where I live as oil leaks cause a defect if coppers see a drip.
When the oil was changed it was stripped open and re-sealed. All leaks are definitely via the top pipe.
Can you use a catch can or breather? Why does it happen?
I don’t know what would cause it but a breather can and allow it to return should work
I think it might need to be bespoke but I guess you could use an engine breather and modify that to suit.
Well I've been under the car to have a closer look and the pipe itself is actually in good condition.
Have to assume the seal of the rear cover is letting by?
nellyscossy
02-04-2012 10:47 AM
Jasesapphy
15
05-08-2005 10:15 AM
