Cosworth 4wd springs option, ahmed bayjoo no good
So I got the famous ahmed bayjoo fast road springs
the problem is, as many have mentioned. It's too short, loosens at ground clearance.
Graham Goode sells uprated springs, someone who has tested them?
I finally got hold of a set original springs.
Yes in Norway there is no chance of getting a car through a check with springs that are loose, as is the case with ahmed bayjoo.
Are Woodford garage spec springs long enough that they do not loosen at ground clearance?
Where did you buy them?
The Ahmed springs on both my sapphs are not loose. But in the past when I had standard Sierra front struts on my Sierra 24v the front springs were a bit loose. That was because standard Sierra struts are slightly longer than Cosworth struts. Now with the cosworth struts on it’s fine.
For anyone who might wonder
The original Ford springs and Eibach have the same length (front)
They fit perfectly in front dampers and whil NOT loosens at ground clearance.
Riding height is not the same of course
reisskahn
14
01-12-2007 10:33 PM
KSA-Cossie
28
08-02-2007 08:48 AM
