Anembo cam pulleys?
Anembo cam pulleys?
I there anyone that running or has some input about Anembo cam pulleys?
Thinking about them..
http://anembo-engineering.mybigcomme...shaft-pulleys/
Otherwise, I think of Quaife
https://shop.quaife.co.uk/ford-coswo...t-pulley-steel
Regards/Jonas
Regards/Jonas
I think they are probably made by MK motorsport. Lots of people running them.
Loads of the pics show identical parts to the ones on my car.
Agreed it is very good kit.
I expect you would pay more for quaife but doubt there is much difference. I would get the timing checked 100% once fitted.
I know for a fact that some of his parts are MK, if you look at the pic of the Wrc front hubs on his site under the ford section you will see a pic of my front hubs that were made by MK.
Doesn’t mean they will necessarily be made by mk...
Cheers Paul
some of the pics on his site have some made by Turbo sport.net too
Cossy Mike (07-03-2018)
Your wrong son , Greg has some wrc stuff off him but most of his billet stuff is made in the factory his pulleys are off turbosport , he makes his own wrc uprights tcas and compression struts as his are turned and not welded as mks , he make his own plenums and fuel rails , and loads of other bits
Ok, I will stand corrected, but I KNOW Greg has quite a bit of gear off him to sell.
I have not said he didnt make his own stuff, just that MK does make stuff for him...which he does.
Never mind, I was only trying to help by saying the Pulleys are good.
I know , it's not a problem , just to let people know that he make a hell of a lot of billet parts him self but he does has part off other vendors , as most business do , his work and customer service is second to none .
Agreed, I have bought off him before and he holds stock which is important in this industry.
I couldnt give two hoots who makes a product as long as it is good and delivered when expected at a good price.
your wrong mate,he doesent make his own tcas and his comp-struts are welded
mark
So, what do we think about
Quaife Steel:
Or
Turbosport:
https://www.turbosport.net/product/f...grey-anodised/
Quaife feels more "safe", uses the design i rallying. Turbosport looks more like a normal adjustable cam pulley..
Is going to this motor (The pulleys on pic is no longer used)
Regards/Jonas
Quaife Steel:
Or
Turbosport:
Regards/Jonas
I like the fact the Turbosport ones use 6 bolts to lock both parts of the pulley together rather than just 3 like on some others.
I think so too. Is most for the Quaife pulley..
Regards/Jonas
Quaife vs Anembo Peg type?
http://anembo-engineering.mybigcomme...leys-peg-type/
Can't deside..
Regards/Jonas
Can't deside..
Regards/Jonas
Can't deside..
Regards/Jonas
Can't deside..
Regards/Jonas
which ones did you end up buying? Are you satisfied with them?
Thanks!
-Timo
Paul500+
17-12-2012 05:38 PM
SaphCos4x4_Dan
02-10-2011 08:28 PM
Stavros
42
08-03-2007 06:31 PM
