Cosworth 2WD ECU Repair
Hi All, Hopefully someone can point me in the right direction. My car has had an intermittent fault as in slight lumpy when hitting the throttle at times. I put it down to a bad plug or lead.I replaced all plugs, leads and cap but again the same was happening. Then today while out driving the car goes dead on cylinder 1. I checked and spark present but no signal to No1 injector. I checked wiring between ecu an injector and all is good. This leads me to a fault in the signal from ecu to No1 injector. Does anyone have any experience of similar faults or does anyone recommend a good place to get the ECU repaired at a reasonable price.
