Won't change down gear (type 9)
Oxygen Thief
Hi all. I've just fitted a replacement type 9 box into my xr4i. The gearbox goes up the gears without issue but it is a real struggle to go down, to the extent that sometimes when trying to pull it into gear (for example 5th to 4th) it'll grind then eventually go in with a real heavy click.
Really hope it's not a dud box that I have and is there anything else it could be like a stretched clutch cable? I've also fitted a new adjuster clutch quadrant at the same time the box was changed.
Advice appreciated.
Advice appreciated.
Robmatheson (12-03-2017)
Advice appreciated.
Advice appreciated.
Oxygen Thief
Yes, it's got 75 90 semi synthetic in it.
The strange thing is with what you have is when the car is stationary it goes into the gears with no problems so that seems to rule out clutch problems.
Faulty clutch would be the easiest thing to fix but if you can rule that out 100% you have to suspect an internal gear selector problem.
Was it a rebuilt gearbox you have put in? If so it must have some sort of guarantee on it?
Oxygen Thief
How much movement have you got in the clutch pedal from when you put it in gear with pedal down to it fully engaging and moving off? Even if you have a clutch problem changing up is still always easier than changing down.
I think I've made a bit of a f*ck up myself and fitted the wrong adjuster quadrant. It was a white one that was originally fitted and I've fitted a black one. Apparently they're slightly different according to colour (although looked the same when I had them next to each other on the workbench). So I've ordered a white one. Hopefully this will sort it. 😳
Not much movement, pretty low bite. It was a gearbox from a scrap car so no guarantees!
Oxygen Thief
Well I've fitted the correct quadrant now and it doesn't seem to have solved the problem. It's as if the clutch isn't operating fully. Is there a trick to adjusting the clutch once the cable's fitted or?
Bloody strange as there was no issues before the old box shat itself.
Oxygen Thief
Right I'm going to change the gearbox oil again as a last resort before the box comes off again. I've got the propshaft out of the box and the front of the car jacked up to drain out the oil.
Ive read a few various threads online about which oil to use. Comma Sx75W-90 GL4 is what's going in. Anybody have any objections to this oil before I put it in 😂 ?
Oxygen Thief
Comma was what the kit car forum lads where advising to get, what would you recommend? I've not tried that, would the quadrant adjuster not just readjust automatically though ?
It was still the same. I took it to my mechanic mate and let him take it for a spin to get a better idea. He reckons it's the clutch dragging, so I've ordered a clutch kit! Fun job for next week!
Oxygen Thief
