Cosworth over fuelling
Hi all, just a quick question , have a sapphire cosworth rally car , running 803 green injectors 3 bar map sensor, lately got engine rebuilt, got car running but it's seriously over fuelling , plugs are black after a few minutes running , also fitted new blue coolant sensor and black/brown air temp sensor , plugs are iridium ngk , what else could cause the over fuelling
Ill have another look this evening , i set fuel pressure reg to 45/50 psi i think which is around 3 bar , have a standard fuel pressure reg i can try on it anyway, i mite give the injectors a clean out too incase they are leaking or blocked
Never went near the co2 screw at all , i just checked and the map sensor wasn't replaced 3 years ago , but could it go faulty if it was just sitting around
Have it been stored inside? Check the vacum hose to map, that can be worn. If it`s stored outside, rain can come into map plug through bonnet vent. Also seen some header thanks With cracks, thats leak into map plug. Before i move my map, to above inlet, i got rain in it, and my monitor showed 3bar boost with just ignition on, overfuel like hell.
