Airbox pipework 2wd 3dr
The car's stripped, sonthis is the only pic I've got. The pipe coming out of the airbox top right is going over the cam cover, to the back of the engine. Normally that would go to the front and into the intercooler I guess, on a STD settings. What do you think has been done in the past? TIA.
Breather pipe probably goes to the kidney box under the inlet manifold, would of been a solid shaped plastic pipe originally, it wouldn't of gone to the intercoolet, just cap it off if you are putting on an aftermarket breather system.
