cosworth clutch pedal
Got a strange issue hoping someone can help.
my clutch pedal is self releasing constantly. i know you have to pull the pedal upwards to release the ratchet but my pedal is sitting at its highest position constantly. it rathcets up, but every time i release pedal with anyhting other thatn ultimate care, it hits the release stop and releases the pawl. :wall: basically with the clutch cable attached i can pull the cable at the gearbox without anyone pulling the pedal up as its already at the release position,. also without the cable attachced, the pedale stays at the highest position. im sure on my last cosworth without a cable attached the pedal springs to the floor. its as if theres a spring missing to keep the pedal away from the release position. any help would be appreicated. |
several things, mostly they will involve removing the pedal box
but that's going to be the easiest way to cross it off the list the other thing might be the clutch itself removing the box (pedal) is 3 nuts and 1 bolt removing the box (gear) is probably much more of a ball ache |
You might as well go the full hog and fit a Reyland hydraulic conversion and get a benefit from it.
had a decent look tonight and not 100% sure the pawl looks good. ive ordered a new rathet kit from ford. they offered white black and yellow, so went with what was already in which is white. knowing my luck it will be the wrong one :cry:
Originally Posted by chrisa3
(Post 6712141)
white, black, yellow and red i would have though it would have been yellow but i've been known to be wrong in the past :cry::cry::cry: |
Originally Posted by dojj
(Post 6712148)
there are 4, depending on the clutch fitted
1 Attachment(s)
Mine was constantly self adjusting because the bracket at the end of the pedal box on the clutch pedal end that the pedal shaft goes into and the cable goes through had fractured meaning it was flexing, its a common fault iirc
Attachment 13548 |
Originally Posted by steppy
(Post 6712297)
http://i632.photobucket.com/albums/u...psjxwj6ug6.jpg |
Glad you got it sorted, I welded mine back together then got a new old stock one that popped up on eBay
© 2024 MH Sub I, LLC dba Internet Brands
