2.0 duratec in Sierra
Hi all wanting to put a 2.0 duratec in my Sierra and wondering if anyone has done it before and any advise any pics, what engine mounts? What clutch? What gearbox? Exhaust?
Thanks Daniel
Thanks Daniel
You can buy an adaptor plate to fit the MT75 gearbox to the Duratec he engine and also a rwd sump. As for engine mounts it may be worth looking at something from Mazda or a ranger that's rwd with a duratec
First post.....
I have had a 2.0 duratec in my xr4ti for about 3 years now. In this picture you can see 44mm Mikunis. Running Jenvey ITB's now.
Spec:
2.0 focus duratec, non vvt. Mazda MX-5 flywheel and starter, MX-5 transmission. Ford Ranger 2.3 duratec oil pan for the rear sump.
With 2wd subframe clearance between the oil pan and the cross member leaves about a 1/4" and makes the fire wall a squeeze. I am collecting parts to install a 4x4 cross member so I can gain clearance on the firewall. I will also go forward with leaning the engine over 10 degrees to right the transmission. FWIW I haven't had any issues with the trans leaning towards the driver.
Spec:
A 2.3 dohc i4 hybrid with an Rs2000 top end will make good power but it's a lot of cast iron. May as well fit a pinto. The Duratec is way cooler and will make more power.
Mazda rx8 box will fir with an adapter plate of off the shelf bellhousing, they have 6 speed, close ratio, smaller and lighter than type 9 and won't break. They even have carbon prop on some.
you can get a 6 speed from an MX-5 that will bolt to the duratec without modification. I have one sitting in my garage.
fwiw the trans still weigh close to 75 lbs. A lot of iron inside those cases.
Also the duratec h e is the same as the
2.0ltr eco boost if you want a bit more power
