6degree beam, roll bar choice
#42
If you want it even stiffer you can change the standard drop links with the rubbers bushes in there for drop links using rose joints. I used that on my 4x4 sapph with a 21 mm arb from a Scorpio 24v. But it made it a bit too stiff in combination with the rest of the setup I had so I changed it for a 20 mm from a standard Scorpio. But I think the 21 mm will go back on in a while.
#43
I have my ARB's set on full soft but the plan is to soften the springs and then stiffen the ARB's a bit but I am hoping to get a pro to set mine up for road use.
I have a 4x4 standard ARB if anyone wants it.
jasoft
05-05-2016 06:24 PM
tockwell
09-04-2016 07:38 PM
