how do ya make a 2.0 pinto a 2.0 pinto efi
as above iv seen a few 2.0 pintos with efi on the engine what do you need to do this
is it just simply change the card to the efi intake ? and will this give the car a rev limiter as the carbed dosent and I would like 1 |
you can just put a rev limiter on it, omex do one which is popular
Originally Posted by slider
(Post 6642588)
so I could put a limiter on a carbed engine ? is that a big job ? |
you need a efi pinto engine as the heads have different intake ports for injectors. also full engine loom and ecu air flow meter and a fuel injection type tank and pump. also needs a return feed to tank.
Originally Posted by costina
(Post 6642599)
mite just get running gear from a 2.0 twincam |
why not buy a 2.3 16 valve scorpio and slot that in the sierra.???
(Post 6642686)
All of these are bolt on operations, but none of them quick and easy. If you want a more powerful Sierra, easiest and possibly even cheapest way is to buy one. 2.0i GLS or somesuch shouldn't cost much over there.
It would be a lot of work for the little additional power you would gain, I think I would be tempted into looking into bike carbs etc.
Martin |
© 2024 MH Sub I, LLC dba Internet Brands
