AB07 cam availability
hi there,
i wanted to ask if anyone knows whether the AB07 (Ahmed Bayjoo) camshaft is still available for the yb cosworth, as i dont see it listed in the Kent cams website. many thanks. |
Yes they are, best to call them .
thanks for that KSA.
I've sent kent cams an email so hopefully you're right. |
Try Tony at turbosystems got mine from him and a quick turn around
You can buy them from Newman Cams too.
Rich |
thanks for your suggestions guys.
where's the best place to get Newman cams from? are they as good as the kent cams? |
Originally Posted by Oz_RS500
(Post 6496896)
where's the best place to get Newman cams from? are they as good as the kent cams? http://www.newman-cams.com/ Rich |
thanks Rich.
looking at their website, it looks like they have a distributor in Australia, so i'll give them a call. cheers. |
bringing this topic back up to the top.
the car has been out of action since last year and it's time to get my finger out and sort it out. what would be the best cam combination for fast road and limited track duties (up to 450bhp)? i've been thinking about the Kent AB07 (or Newman PH1) inlet cam, although, what would be the ideal exhaust cam spec? Also, is it worth going for a BD14 inlet given the slightly longer duration & higher lift? |
If you have the valve clearance then I like the bd15 but standard exhaust cams work really well with either inlet cams
I tried to buy one new and couldn't
I was advised to buy a new improved cam call a Tr255 or something Kent - Offered me alternative and could not supply AB07 cam's as they are copy right protected Newmans - Offered there own cam Turbosystems - Offered me a TR255 |
Originally Posted by Jay,
(Post 6583862)
would i benefit though by going for a higher lift/duration exhaust cam, or is it not really worth it? |
Originally Posted by saphcosmike
(Post 6583874)
I was advised to buy a new improved cam call a Tr255 or something Kent - Offered me alternative and could not supply AB07 cam's as they are copy right protected Newmans - Offered there own cam Turbosystems - Offered me a TR255 Alos, has anyone had any experience with the AB07 equivalent Newman cams? |
(Post 6584753)
if the AB07 is copy right protected, then where can it be purchased from, Ahmed Bayjoo himself?
Alos, has anyone had any experience with the AB07 equivalent Newman cams? Mark |
I bought it from Burton a few weeks ago 😊
I got mine from tony @ turbosystems. It's a newmans AB07
MSD have it in their webshop too.
http://shop.motorsport-developments....ind-1563-p.asp Bonus if they have an offer on - as they are known to do from time to time |
Originally Posted by Mark Shead
(Post 6584755)
Email Grove Garage as this is where Ahmed works from so you could buy it direct.
Mark what are your thoughts on an exhaust cam? if i was to upgrade the exhaust cam, am i better of going for the same spec as the inlet, or is it ideally better to go for a smaller lift/ less duration cam? fyi, the car is a road car (RS500), so i'd like to retain (or even improve) response & mid-range torque. cheers, Goran |
i have some options now, thanks for your help guys.
(Post 6584954)
Newmans don't make them. MSD don't have them and will supply you with a Newmans equivilant, I've tried. Kent cams said to me - Ahmed asked Kent to make him x amount of cams to his own spec and he took them, originals have AB07 stamped on the end or KCAB07. Maybe worth a shot at Grove garage but it was a long time ago they were done. Unless he can authorise Kent to make another |
Newman equivalent is very similar with fractionally more lift and duration I'm told.
(Got one going in my new build). |
Originally Posted by Ade
(Post 6585146)
(Got one going in my new build). what kind of results have people (that are running the Newman AB07) seen in their engines? |
Boost held on for another 800rpm at the top
(Post 6585227)
how about power & torque, what was the improvement? which cam is preferred by fast road owners, AB07 (original or Newman equivalent) or BD14 spec? also, if i wanted to upgrade the exhaust cam at the same time, which spec would work best with the AB07 or BD14? FYI, the car will be street driven so looking for strong mid-range to torque/power. |
Just to throw another in the mix - theres the CatCams 2330826 Inlet cam.
Designed for use with std exhaust cam Or their inlet/exhaust combo which is slightly wilder than BD14/10. |
Just goes to show what a great forum this used to be :top: and still is a data bank of info
Looking for some std type cams for my YB powered Mk2 and someone mentioned Ahmed Bayjoo cams as a possible option. I see Kent still list the AB07 and say no piston mods, Burton also list the cam https://www.burtonpower.com/sports-r...new-ab07i.html Burton also lists a exhaust cam but notice Kent dont list it on there site ? https://www.burtonpower.com/sports-r...new-ab07e.html Anyway anyone ever ran these cams in a std head / std piston configuration ? |
Hi,
i did and that time pistons were without mods and engine was on ut t38... it gave just some 490 Nm on dyno during mapping session,it just didnt want to go more..wasnt happy with as i wanted more live car so swapped that one with bd 12 and efr 7064 this time with some worked engine.. that was much much better as the power delivery was way low down and it drives well... |
Originally Posted by cossie2
(Post 6835474)
Hi,
i did and that time pistons were without mods and engine was on ut t38... it gave just some 490 Nm on dyno during mapping session,it just didnt want to go more..wasnt happy with as i wanted more live car so swapped that one with bd 12 and efr 7064 this time with some worked engine.. that was much much better as the power delivery was way low down and it drives well... I have just got my Escos set up with a EFR 7064 BD12/14 cams and although it fast and pulls like a train 3400 on, it is a bit laggy below that, with my MK2 escort i really dont want it laggy, its on a T34 hybrid and was looking for a cam/cams to try and give me more drivability. Going with std cams get it on the road and see how it feels. |
I had also set up like this but went back to bd8 ex and is much better...
© 2024 MH Sub I, LLC dba Internet Brands
