Cossie problem?
Here one for you guys went out in the cossie today popped to the pub for some lunch come out wouldn't start no spark go get my works trailer get back it's start to I drive it on to the trailer get home go to drive it off won't start just gone back out there it starts but now I have no trust to go anywhere init any ideas peoples!
Coil burning out? Bad earth? Rotor arm? Dizzy?
4X4 or 2wd bud
my first thought would be crank sensor or ignition module
cheers nick |
I recently had a sticky/stuck in the end relay that left the engine running even with the key out, maybe you have a relay sticking in the off position?
4x4 what's the best way to check things want to get a lust so I can crack on tomoz if possible
Well have you noticed the rev counter jumping ?
I would check the crank sensor and also the connector blocks on the bulk head the cennter one has the crank sensor going through it so check there all clean and connecting |
Just to add i have just got the iaw diag software from stu when you have issues like this it makes it so easy to fault find
Jay whereabouts in the south east are you and what is thus software your talking about
Cheers bud I'll have a look at getting that
One last thing the only thing I have notice say your driving along a 70 nice in a blue moon it would miss a beat as such
For me wiring loom plugs on the bulk head causing a crank/phase issue
I'll check it out tomorrow buddy can I clean them up with anything grease them up etc?
My 2wd did this it was the multiplug above the ecu , 5 wires ignition/earths/lives.
Easy to rule out. |
Was the crank sensor all sorted cheers folks :top:
When I first bought my cossie I could go for a drive and it would cut out. It would crank and crank and wouldnt start. I could get the car towed home then it would start again. I changed the fuel filter and it been spot on for the past 7 years.
Originally Posted by Jay,
(Post 6445452)
Worth every penny Glenn saves so much time in fuckin about with test lights multi meter ect
Originally Posted by Glenn_
(Post 6446285)
Looks like a cracking bit of kit that Jay.
I got a del 610 on xp with a serial port for the job
(Post 6447120)
My first laptop had a pcmcia slot where i used a rs232 ( serial ) converter. Worked fine. Unfortunatly the new latop didnt have anything like that so had to used one of the USB converter cables. and pop they both went @ £100 a time. :wall: |
The dell cost me £80 refurbed off eBay works great with the older type based software I just use that for all the car stuff
I take it the software cant be copied??
No it's even licence to 1 computer
Originally Posted by mark r
(Post 6447569)
© 2024 MH Sub I, LLC dba Internet Brands
