No cup holders!!!
Would love some cup holders in my sapphire 4x4 but don't want any clip on halfords ones was wondering if I could find/ modify something from another car to fit somewhere and still look factory.
any one got any thoughts? |
Nothing springs to mind, but I find being stationary doesn't spill your drink.
Having owned a sapph, I know they have the odd flat surface on the inside. In fact, compared to new cars it has a dash like a feckin bar. |
Is there not an armrest available for them with storage that could be modded
Perhaps a mk3 mondeo cup holder fitted to where the amplifier goes. They come out at an angle so should clear the gear stick.
Im sure ive seen a saph with vw pop out cup holders fitted, have always meamt to get a set and try fitting them
The mk 4 golf has some pop out cup holders. Just pull up the arm rest remove the cassette holder and put your cup in there.
There are those nice Saab ones which take up very little room which slide into a very small space then open up:
http://www.thesaabsite.com/catimages...?mt=1344128344 Rich |
I believe you can also buy ones that come in a cartridge that is single din size so would slot into the old Ford amp slot if you're not using it.
***Edited*** In fact a quick eBay search comes up with this: http://www.ebay.co.uk/itm/Universal-...item4aa8ed45cd Rich |
There cool.
Cupholders for Ford Sierra
Found somewhere online that the Vauxhall Vectra "C" has a great double cupholder unit in the front of the rear seat base.
Removed the now redundant amplifier from my dash. Went down scrappys this morning and had my choice of Vectras. You don't need any tools to remove the cupholder unit from the rear seat base, lift seat and disengage catches and it pops out. Don't lever the front of the unit as this damages the cupholder. Whole unit almost fills the amplifier hole, I just wedged it in at the top with a rubber block. Once you have adjusted it you will clear the gearstick, just. Easiest mod I have done in ages, wish I had done it before. Hope this helps someone else. |
© 2024 MH Sub I, LLC dba Internet Brands
