N7A in sierra saphire,i need help¡¡¡
Hi, I'm kukotronic, I'm from Spain, I need your help, I have a ford Shapire with which I have been running in the slalom championship and wanted to put the motor escort rs 2000, I have found a donor with everything you need, or I think so, but I need to know if you can really make the engine change and works well, here in the forum I searched for information but can not find anything (I'm newbie) Forgiveness for my bad English written
wesskitzo
Right first off welcome bud, the engine is I4 N7A in standard form it has 150bhp however that is virtually it you will spend alot of money tuning this engine and you will not see much more power gains it can be turbo'd but will cost a small fortune and for half the cost could build a zetec turbo that would run more power too.
But to answer your question yes it will go in the sapphire bay but you will need a water rail I think you need flywheel off a 2ltr twincam sierra the mounts and engine arms and mt75 rwd gearbox and propshaft or use type9 gearbox with 2.9 v6 flywheel and type9 propshaft
WES
WES
My car is a sierra 2.0 DOHC, I'ma mechanic and welder, questions I have are about the placement of the alternator and power steering pump, collector item no problem because I can change them without problem.The turbo issue, my neighbor has put in his DOHC turbo, lots of work, lots of money and little fiabilidad.He found a complete mechanical and electronic one escort rs 2000 for little money, but before buying my question was to attach the Shapire not want to spend the money and then the engine stays in the garage gathering dust.
chowfornow
14
05-01-2019 09:01 PM
SMILER258
28-09-2015 09:04 AM
