Refitting turbo. Advice please.
Evening folks.
I'm just about to fit the turbo back on my 2WD but have a problem with the actuator.
I haven't stripped the turbo down but have had the actuator and compressor wheel cover off.
My problem is the shaft of the actuator now seems too short. I assume that the wastegate flap should be shut but if i bolt it all back together there is no movement on the shaft for the flap to open. I haven't altered the length of the shaft at all but if a put it back on its post with the small clip it's shut and won't move.
So what have done wrong?
I had the actuator changed on it around 15 years ago and not touched it since and assume it was set up correctly and the car ran perfectly but it's as if it was set up and hasn't been able to move.
Is it dangerous for the engine if the flap is permanently shut?
Any advice on what to do?
many thanks.
many thanks.
You need to set the actuator with the correct preload.
This can be done a couple of ways.
I would say the easiest for you would be put the actuator back on the turbo,
adjust the rod so the pin on the arm of the wastegate covers half the hole on the actuator. Pull the rod onto the pin and secure.
Plumb in a decent boost gauge and run the car up in 3rd or 4th gear loading up and check the boost.
To adjust it to what is was, shorten the rod ups the boost lengthen it lowers the boost.
Hope this helps mate.
Other thing, to check the actuator is operating correctly is use a coolant pressre testing pump,
connect it, and pump it you sould see the rod moving out to open the wastegate
Thanks for the replys.
Stupid question time but can you tell me what you mean by
'pin on the arm of the wastegate covers half the hole on the actuator'
Do mean the pin on the post of the wastegate?
And not sure about half a hole on the wastegate.
I am a muppet.
Cheers.
I am a muppet.
Cheers.
The end of the actuator has a hole in it the waste gate arm has a post that the actuator rod attaches to when the actuator is bolted to the compressor housing the actuator should have half a hole preload ie the pin on the waste gate should cover half of the hole on the actuator rod you will then have to pull the actuator rod towards the waste gate pin to get the actuator to fit over the waste gate arm pin does this make sense ?
Yes mate, just been to have another look and i get what you mean.
But, with half a pin preload i cant then pull the actuator shaft over the pin, its too short.
So. i lengthend the shaft a bit so it would fit over but then when its all in place the shaft wont move backwards or forwards.
So how do these things work. Im guessing there is a spring in the body and with the shaft fitted there should be some play in the actuator so it can move rearwards to open the gate under boost.
In my case with it all fitted, the shaft is allready rearwards, as if the spring if fully extended and its all locked up and wont move.
Hello mate.
With the arm disconnected there is a lot of free play. When i connect it back up, and its set to the same length as it was before i took it off, the whole thing wont move at all which means that the shaft cant move and open the wastegate.
I cant understand why/how its set up like this because the wastegate cant move. The gate is in the closed position but there is no rearward movement in the shaft, the rod when connected will not move backwards at all to open the gate.
In this position the diaphragm is up against the back of the acutator body.
How far away from the pin on the waste gate arm is the hole in the actuator rod ? Are you sure you have fitted the actuator bracket on the comp housing in the right place ? Have you got the orientation of the comp housing in the same place as it was when fitted to the car ?
Hello mate.
If i put the acuator shaft back on the pin, then i cant bolt the actuator back on the comp wheel housing. Or, if i bolt it on first, the shaft is no where near the pin for the wastegate.
Again i havnt altered the length of anything yet, its just as i took it apart but it wont go back together!!
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
