cosworth pistons problem!!
Hello to all,this pistons is genuine mahle and std,have done about 30000 kilometers,so this side of the pic is from exhaust,and the up ring have stick,so in this case is from poor fuel? thanks in advance
Regards Thanasis
image upload
Regards Thanasis
image upload
Regards Thanasis
image upload
Regards Thanasis
image upload
Look at the pepper makes around the crown edge you have been detting.
Look at the map and if the car/engine has any faults.
Mark
Yes as said detting so running a little to lean or if this is just on one cylinder maybe an air leak some where on the same cylinder..
Make sure you check everything thoroughly and if maps good and theres no leaks or evident sensor faults then look at fuel system etc..
cheers danny
cheers danny
cheers danny
cheers danny
all sensors are new,but this problem is with my old map,and i don't had check about AFR,now i'm running from MSD closed loop,and i have rebuild new engine now.
thank you very much
Thanasis
Air Leak on turbo engine? How is that possible?
with new engine sensors? Possible ecu map fault!
Now with new engine rebuilt and MSD Closed Loop I don't think that anything is going to happen again!
big_Rad
15-09-2017 09:36 AM
ekjim
17-08-2015 08:57 PM
Zoggon
10-08-2015 10:39 AM
