LUK Clutcthes!
LUK Clutcthes!
My clutch is starting to slip and ive seen these LUK standard spec cluthes for sale and was wondering has anyone on here used them?how are they and what kind of power they good for?
i've had a LUK in mine since 2002 on stage1.
it's done nearly 100,000miles with it in and never had any problems with it, i recently took the gearbox out for a rebuild and checked the drive plate while it was out and there's still plenty of life left in it.
if it goes i wouldn't hesitate to fit another one, with more power it might be a different story though
cheers nick
cheers nick
MERKUR XR4ti
I have found the the LUK clutch is as good as you can get for a real world price. Iv used one with 330+ whp with on issues. if you abuse anything it will fail in time.LUK are fitted to all German high performance car from the factory and that says a lot to me, as we don't build anything any more lol IMO ap are over priced stock Ford clutches are well over priced performance clutches.
I run a standard luk in my mk1 with 330bhp no problems. Not a heavy car & runs on 13" wheels so this takes some stress off the clutch but a good quality clutch. Done a few trips to pod & it does get abuse when needed
My experience of them is they are as good if not better than the new motorcraft items you can get these days?
If you planning on running a fair amount of torque fit a 6 paddle or you will be taking the box out again to fit one
Cheers for feed back on these clutches,im only planning on getting car chipped,with full mongoose exhaust and airfilter this year so want be silly power(2wd saph standard t3 and injectors).But i want get upto stage 3 next year so it may be a case of getting an uprated one now.
I fitted a new cable and ratchet thinking that might be the problem and still no good. Then had to go for the ap heavy cover and it's been fine for the last 2.5 years! And the pedals not as heavy as I was expecting.
All that was on 329lb torque, however some folk seem to get away with more on std clutches? Upto you but taking the box out for the fourth time gets annoying!!
Having said that i have had a standard ford item fiited to mine for over 15 running stage 3 365bhp. Slips a little on track days when driven in anger towards the end of the session when hot.
When i checked with Ford buying one trade £150 all in inc vat (3 piece kit)
Ian
Ian
Ian
Ian
My mate ran 450hp in a 4x4 with a standard clutch and it held ok, although it wasn't run for long like that
unless there was a bad batch of them a couple of years ago? Still don't think I'd buy one myself?
JasonXR2Racer
18-04-2012 03:12 PM
