7.4:1 compression ratio on 4x4 yb, opinions please
Opions please?
To low? Nice and safe etc I'm new to all this
Seen some cosworth racing pistons on 7.4:1 ratio with valve cut outs and that have done dyno time only & wondered if they would be ok for my engine
200 10 studded block
Shot peened rods
Arp rod bolts
Fully worked crank, knife edged, L&B etc
High torque cams (not 100% sure on spec at this moment as info not with me)
Gtx3071r turbo
2wd manifold with tial 44mm external gate
Hart inlet with 4x4 throttle body
Power guesstimate for the above spec also please, I'd like to see a genuine 500bhp
Any info appreciated
Thanks
Marc
Shot peened rods
Arp rod bolts
Gtx3071r turbo
Thanks
Marc
B1mbo
The problem is, they were 7.4:1 cr in that engine they came out of, they may have stopped the piston 20thou down the bore. If you block has a low deck heighgt you could be nearer to 8:1 again. Also are they 7.4 on a 4x4 head or 2wd? Cosworth pistons are a good piston, may be worth getting them and dummy building your bottom end to work out the cr.
I will have to look into it a bit more,
Is there a way i can measure the block height on the bench? the block is bare, where would i measure from if you can, deck face to ?
Is it worthwhile cc'ing my head then while im bored working nights then i may get a better idea whats what
*** Sierra RS Custard ***
You just use a feeler gauge from top of piston to top of block, but it will need to be a complete bottom end when you do so, ie crank rods and pistons in situ, you cant really measure just the block in isolation.
Yes its worth cc'ing everything if you want an accurate CR figure.
1st to 200 without NOS
You can get a good idea if the block height is near std by measuring from the top of the main bearing to the deck face, its not exact but you'll know straight away if there's loads been removed from the deck face. 6973 thou is what most of mine seem to be.
The head is prob the biggest factor and what the pistons were specced for..
If the pistons were 4x4 and you run a 2wd head the cr will go even lower but if the pistons were 2wd spec and you run a 4x4 head then the cr will be around 7.7.1 if the head and block were of near std origin,ie block deck hieght and head depth..
Basically you need to know what the pistons were specced for and then measure your block and head to get a better idea..
Also you need to know how old the pistons are because if theyre old 2wd spec ie no offset gudgeon pin it will sound like an orchestra on warm up under your bonnet!
Check out ebay mate as julian godfrey has some nice piston sets for sale at a reasonable price and theyre new old stock..
Ps
With your spec engine mate the cams are pretty vital and cr wise i would aim between 7.8.1 at lowest and up to about 8.3-8.4.1 at highest..somewhere in this region with the right cams will be awesome and on a gtx3071.82 should see around the 550hp 500 lb ft region fairly easy
cheers danny
Ps
cheers danny
Went down to FMS today with the engine and handed it over for the full build to commence, let the pro's do what they do best
Tommy had a set of cosworth racing pistons on the shelf as well, brand new, valve cut outs, coated skirts, rings pins and are perfect for the compression ratio he is gonna go with on the engine so happy days
Best start saving
Best start saving
It Wasnt Me!
They look fairly low comp!?
I don't understand why you wouldn't go low comp? can run more boost, more ignition advance and make more power....???
High comp means less boost, more retard unless on some fancy fuel...and less room for error and increased chance of det.
All the high powered cars i've ever saw (not read about, or heard about, I mean SAW) have been low comp!
You do misunderstand how it all works. Maybe if he was aiming for 1000bhp, 7.4:1 might be justified.
For only 500bhp it would be a totally ridiculous CR to aim for unless he had no intercooler or some other huge failing.
It Wasnt Me!
Clearly you do, away and read some more stuff on the net Stevie
*edit, out of interest...seeing as you feel so strongly about it*
What's "totally ridiculous" about going low comp
If it's not that big an issue...why do manufacturors lower CR on turbocharged cars vs same engine/NA?
What is the problem you think occurs when going low compression?
Hmmm nope, cant even find any even on the internet
The only problem is you end up with a soggy uneconomical piece of shit that doesnt make the power it could because it is an inefficient package.. I can think of few circumstances where I'd build turbo engine with less than 8.5:1. And if there was any, they would be extreme and for a specific reason.
500bhp is neither extreme or anything of that kind.
And manufacturers maybe drop from 10 or 11:1 to 9:1 these days. Some may venture into the 8's, but even these are becoming less common now.
7's...that shit is 70's and maybe 80's technology. This is 2012 believe it or not. Get with the times.
And thats with never building any engine as low as that !
If you've never built and tuned any engines as seems to be the case with you...I guess you just wouldnt understand.
i was running 8.1 with 539 hp in 96 and that engine was the bollox,my last 642 hp engine was running 8.4 cr with no probs and my new 700+hp engine will be around the 8.1-8.4 cr(i havnt got the exact rod length yet)so i agree that 7.4.1 these days is pointless!!
cheers danny
cheers danny
It Wasnt Me!
Im not saying it can't be done, Im just pointing out that by less CR, you can run more advance...less heat, less chance of det...more power for less boost.
"70's technology" good one that!
Anyway my breath is clearly wasted here, carry on!
It only makes for a horrible of boost car and really isnt needed these days
cheers danny
B1mbo
Show me a decent production engine that's as low as 7.4:1 ?
What manafacturers spec their engines to run 32psi of boost?
What you have to keep in mind is the yb is a bit of an old boat anchor, they don't like massive compression ratios. for big boost applications 8.0:1 seems to suit them perfectly, for a road engine that is going to do lots of miles with big boost then a touch lower is good IMO.
I do have to agree that 7.4:1 days are gone, I don't think we should be seeing under 7.8:1 any more.
I take it you have a 4x4 head thats had a bit of a skim then?
Them bowls look quite big in the pics and with valve pockets too it looks more like a 7.8.1 cr? obviously all depends on head etc and 8.2.1 would be awesome any way..
cheers danny
