Electrical power steering
Can anyone help me I any restoring my 3door Cosworth from scratch and all my power steering parts needs replacing and I was just thinking about converting to electrical power steering has anyone done this and help me in which parts to get for the best result and how easy it to convert thanks for the help
Darren
Darren
cossie fan (unluckerly)
my mate has done it with a merc a class set up! i thought about it but couldent think of where to put the pump as i dont have any room under my bonnet
saxo pumps are massive!
big floppy donkey dick
Citroen C5 style can be remote mounted anywhere, as can most modern elec fluid type
brand new is only £380 also, result!
wired a fair few up pn race cars they use the corsa setup with a little control box connectoed to a potentiometer to adjust how much effort you want it to give you. if you want to source the parts i can get a prive for the box of tricks if you want
What about this "saxo" pump that will keep the hoses? And could you make it up with a saxo pump to only be switched on at slow speeds so you get more "feeling" though the wheel feeling what the Tyers are doing more? Or is that only for the "corsa" electric setup?
i cant see the point in swapping from the standard hyd rack pump and hoses to the same setup just with an electric pump. the corsa setup is such a neater job. wired up 2 on series 1 landrovers used for offroading well over 2 years ago now and are stil going strong so just goes to show how much theyll actually take!
07-10-2015 12:56 PM
