cosworth rattle/ticking/knocking
Got a 2wd sierra cosworth which starts cold with the normal slight piston slap & sticky tappet, But once warm and driving its fine but when under load in any gear there is a tapping/knocking noise
Now i know its not big ends as its far from that bad but just wanted to see what people think this could be ? Its a 205 block still with dark greens, t34 turbo @ 1.5bar with chip to match, The car drives fine apart from this noise it had a oil and filter change about 500miles ago and it didnt change a thing using 10/40 Oil pressure is very good the light always goes straight out when started |
Lifters most likely, you may get away with just cleaning them, that is if you don't mind removing the top half of the head, i.e. cam cover, camshafts etc.
Or it may well go by itself given time, someones giving it a bootful can help as this gets the oil hotter and thinner, and so may well clear the blockage, this is assuming you have a good quality oil and it's been changed regularly etc. Martin |
yes mate was changed not long ago but doing it again tomorrow i think :) Tryed a good session of 145mph but still there :(
Ticks over fine and cruises fine just when its being put under load to pull the car along, Strange really just hope its not serious |
Had mine out 2day & heard a ticking sound when on boost. Had a look at it there it's the exhaust maifold gaskets blowing out. It sounded like an internal knock or tick from inside the car.
but looking at the car when ticking over there is no sign of a blow :( but guess it only has to be a small blow to stand out when under load
Originally Posted by mr noisy
(Post 5729228)
© 2024 MH Sub I, LLC dba Internet Brands
