99 turkish 200 block
ive got a new 99 turkish block. going to be putting a t38 on it.
i suppose bhp will be 400 ish would you use the block?? thanks |
Yes you wount have a problem
CheeRS stu |
Nothing wrong with them blocks i'd use one at 500+ heard of more old 200 blocks cracking than 99
makes me laugh when people refer to blocks as 'Turkish'
Seen as every block was cast in Turkey then sent to Germany for machining does that mean we all have something to worry about? There was however a batch that were miss cast leaving the bores of centre by around 5mm most of which were destroyed with only about 50 or so slipping through the net!!! If your un lucky enough to have one of those forget about 400bhp |
had 530 bhp when i had my saph with no problems and its still going strong now
Originally Posted by tiny2white
(Post 5558505)
Seen as every block was cast in Turkey then sent to Germany for machining does that mean we all have something to worry about? There was however a batch that were miss cast leaving the bores of centre by around 5mm most of which were destroyed with only about 50 or so slipping through the net!!! If your un lucky enough to have one of those forget about 400bhp The ones with '99' cast into them are the batch that can cause problems. Their ARE loads of those around & at 500bhp its perfectly fine. At high 600's a new 99 block have been found to warp. I know cos i measured mine :cry:. MADAde has a 99 block used at low power & fully heat cycled that is currently OK at 650bhp. |
Originally Posted by MadRod
(Post 5558524)
No!! only a single batch are causing problems
The ones with '99' cast into them are the batch that can cause problems. Their ARE loads of those around & at 500bhp its perfectly fine. At high 600's a new 99 block have been found to warp. I know cos i measured mine :cry:. MADAde has a 99 block used at low power & fully heat cycled that is currently OK at 650bhp. and why do people refer to them as Turkish? |
What's the limit with this '99-block?
I have '99-block (90.5mm bore) with original head bolts and it has dynoed 608.4hp@8098rpm / 593.4Nm@6803rpm. If I lower the power to approx 500hp and increase torque, does it hold together? |
Originally Posted by Jasu
(Post 5861301)
© 2024 MH Sub I, LLC dba Internet Brands
