bulbs for sapphire
Hi Guys can someone confirm what bulb goes in the spot lamps for a sapphire, is it H3 with wire or without ?? I cant remember..
Also is the headlamp a H4 bulb ?? im sure it is... And finally what bulb goes in the front indicators |
Your spot on :), H3 for the fog lights with a wire and H4 for the headlights (55W/60W)
Indicators are 21W single filament and 5W cap less bulb for the repeaters. Martin |
cheers mate :top:
Ring Rally 130watt H3 work ace(with relay/rewire), and H4 160/90 Ring Rally for the headlights in place of the H4 60/55, again needs rewire.
If you don't want to bother with a rewire/relay job then Halfords Super Brilliance are the best std wattage bulbs I've found. tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
