3dr and sapphire mirrors the same?
as above are 3dr and saphire door mirrors the same?
im 99% sure they are jeff
No they are not, Saphs are heated 3DR'S arn't!
IIRC the actual housing may be the same. Martin |
im glad i didnt say 100% now lol:cry:
3 door ARE heated, at least they should be, my mk1 sierra gl had heated mirrors so can't see the 3 door not having heated.
There is a difference between the moulding that attaches it to the door, with some having a recess where a trim bead goes, but they do fit . tabetha |
(Post 5507102)
cheers for the replys guys,im after a drivers side mirror for my 3dr theres plenty on ebay but dont state weather there for the 3dr or not. |
The difference really isn't noticeable unless you look for it, it has a step about 10mm wide l around the mirror bottom and side at the front, still the same color, on my gl it had std fit silver trim bit there, hence the recess.
I used to watch the water evaporating off the mirror when I put the heated rear screen on, as they were wire through that, trouble is it left spots all over the mirror glass so constantly had to clean it. tabetha |
i'm with tabs on this one mk1 door mirrors where heater. i have four in the garage 2 from a 85 2.0iS and 2 from a 84 XR4i and you can clearly see the heater wires coming from the glass,
http://img.photobucket.com/albums/v6...h/000_0649.jpg and as tabs has stated already mk1 and mk2 mirrors are not identical but the do fit each other |
They may well be heated on some models of 3dr sierra but I know that on my 3dr cosworth they are not heated.
Originally Posted by g10ens
(Post 5507970)
the problem is that the heated glass was and still is very expensive compared to the non heated glass |
I have just supplied a genuine ford HEATED wing mirror glass to one of my customers with a 3 dr cosworth....his ws original and specifically wanted me to find him a heated unit as they are now obsolete
They are heated - at least the ones on my moonstone 3dr were heated and I have several spares so if you need one pm me
I stand corrected, it does make sense they would be due to the trim level of the car.
Martin |
© 2024 MH Sub I, LLC dba Internet Brands
