suspension
hi i have a 4x4 sapph on koni adjustables the bacck sat realy high and it wallowed on corners so i bought avo 25mm springs and fitted them but it made no differnce to the height at all does anyone have springs they would recommened or a way of dropping it a little:wall:
Ideally you want the rear slightly higher than the front, but replacing the set of springs would get a better match height wise, like the excellent avo/chassis dynamics std ride height or ahmed bayjoo ones.
Fiddling with spring height will not stop wallowing however, I assume you have a std diff mount ?, if so junk it now, as it was crap when new let alone with age, and change the rear arb for a 22mm one, the std rear suspension/diff is a joke performance wise, and needs ditching. tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
