Replacement Injetor Seals
Has anyone used the below injector seal kits before?? need to replace mine and not sure if these are any good?
http://cgi.ebay.co.uk/FORD-COSWORTH-INJECTOR-REBUILD-KIT-YB-TURBO-2-0-2WD-4WD-/290565785721?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item43a7120879 http://cgi.ebay.co.uk/Ford-RS-Cosworth-Injector-seal-Filter-kit-/150596403274?pt=UK_Cars_Parts_Vehicles_Other_Vehic le_Parts_Accessories_ET&hash=item23103ec04a |
I've not used those one themselves but they are the real deal, it may be better though if you have a injector issue and getting them cleaned to leave it to the "cleaners".
You don't say what injectors you're using but if greys you need a additional "fitting kit" for each injector, but if already have the fitting kit need a different top seal. tabetha |
Originally Posted by tabetha
(Post 5466252)
If they're not leaking I wouldn't bother tbh.
DON'T UNDER ANY CIRCUMSTANCES USE WD40 on the seals to aid fitment, this dries them out and can cause ripped seals when trying to force them in the rail/inlet. Just use some std hmp grease on the seals, they will literally fall in, or out as was the case yesterday for me, then had to clean it all up again, they go in so easy just the weight of the injector can make it slide out again from the rail, so I put them all in the inlet first, put rail on top and push down gently whilst wiggling from side to side slightly, don't worry too much if a spec of grease goes in the filter basket on the top of the injector, the petrol disolves it and causes no harm. tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
