best oil 4 my 500 bhp 3dr
my car is running low on oil saw was wondering what is good oil to put in it???
I use mobil 1 15w/50 motorsport stuff !
Originally Posted by mechanic28
(Post 4569626)
A lot of people on here are using Silkolene Pro S 10w50.
Originally Posted by Staffi.
(Post 4569659)
Is that just 500bhp Specific then Doug ?? ;-):blabla:
protect
Silkolene PRO S 10w50 without a doubt,great stuff,if you have nosiy tappets it will quieten it down a bit plus you will get better oil pressure reading over other oils.
Silkolene is the way to go,not cheap but u get what u pay for. CheeRS.Lee. |
(Post 4569801)
Yes special oil for special people :cry::cry::blabla::king:
Originally Posted by 1374lee
(Post 4569823)
Silkolene is the way to go,not cheap but u get what u pay for. CheeRS.Lee. ^^^ Agree 100% Lee.........:top: |
(Post 4569823)
have been thinking about using that oil,but i get the mobil one stuff quite cheap £33 for 5 litres!only problem is with the big wing sump it takes more then this now :cry:
protect
Originally Posted by TiB
(Post 4569837)
Gotta disagree on some of that from my findings.. millers 10w 60 or castrol edge 10w 60 keep much better pressure, silkolene seemed good enough but just doesnt last long at all before degrading and the pressure starts to drop.
I understand what u r saying but SILKOLENE keep it's viscosity at higher temperatures where some other oils lose their viscosity far quicker,Castrol being one of them. I cannot comment on the Millers but I have heard it's good stuff. CheeRS.Lee. |
oi hello nothing wrong with the mobil 1 stuff either
(Post 4569909)
Meeeowwwww.......:cry::cry: |
(Post 4569912)
wheres that spamming train driver! |
(Post 4569909)
CheeRS.Lee. |
(Post 4569955)
(Post 4570023)
Doug,Mobil 1 was yet another oil to lose it's viscosity at high temperatures.
CheeRS.Lee. really?would not of thought that tbh,but then again i aint really looked into it!i presume you mean using it hard on tracks etc,i have always used it and never had any problems with it? |
(Post 4570042)
Doug,I saw a test done on quite a few synthetic oils last year,can't remember where I saw it now.I'm not knocking Mobil 1 or any other oil,just feeding back the results of the tests that were carried out at the time. Doug,I have used mobil 1 in the past aswell,the loss of viscosity does occur at high temperatures as u say more likely 2 be the case on track when u r constanly hammering it but don't forget these cars run at very hot temperatures anyway(road use),just some food for thought fella. CheeRS.Lee. |
(Post 4570260)
Doug,I have used mobil 1 in the past aswell,the loss of viscosity does occur at high temperatures as u say more likely 2 be the case on track when u r constanly hammering it but don't forget these cars run at very hot temperatures anyway(road use),just some food for thought fella. CheeRS.Lee. indeed mate!thanks for the info!:top: |
(Post 4569874)
I cannot comment on the Millers but I have heard it's good stuff. CheeRS.Lee. Your supposed to be at work :bat: |
(Post 4569955)
I just use 10/40 in mine, never had any issues Steve |
(Post 4570030)
Hopefully stuck @ Paddington Doug....:content:
St Pancras, Victoria, Cannon St, Charing Cross, Blackfriars are the ones i go to :top: Steve |
We generally recommend the Silkolene Pro S 10w-50 but there are others to look at. Motul 300v, Gulf Competition, Redline or Millers but we dont agree with 10w-60 unless oil temps are extreme.
Cheers Guy |
TORCO full synthetic 5W/50 top oil but expensive!!!
yacco galaxie 15w50 competition
The Castrol also expands at high temps, as the molecules "unwind". Therefore in a Cossie (which doesn't like being over-filled), you will "appear" to get high oil consumption if you fill it up to the top level, as when it gets hot, it will go over the level and then get blown out the breather system. When it then cools, you have "used" a lot more than normal...
Silkolene for me, as in Rod's car (200mph) it showed NO chemical breakdown at all after a high speed run (where the same could not have been said of the others, which had sheared and lost a lot of their protective properties ;)). |
Best I have ever used was/is SUNOCO RACING 20W50, REDLINE would be my 2nd choice.
The cossie doesn't run any hotter, but does have less oil than a lot of other engines so has to transfer same heat with less oil, not forgetting oil does at least as much cooling as the water cooling system. tabetha |
Originally Posted by tabetha
(Post 4574299)
And it takes so long to get around the engine when it's cold, go for a 10w-50 or 15w-50
Originally Posted by oilman
(Post 4708999)
I run a little less - 437bhp at the wheels and have been very happy with it ;-) |
Originally Posted by AndyPen
(Post 4710637)
Been really pleased with the silco myself... refitting the big wing sump so will be in for more soon ;-)
© 2024 MH Sub I, LLC dba Internet Brands
