coilover opinion saphire 4wd "HELP"
hello,
i own a 4wd sierra cosworth sapphire with stage 3. I fit 17x8 revolution wheels with 215/40/17 tyres. I have the koni yellow adjustable shocks with eibach springs but all the suspension is dead... I want to fit a new one coilover type and i want to hear your opinion for the best solution! the options are 3
A. GAZ coilovers
B. AVO coilovers
C. Bilstein coilovers
i'm from italy and the streets here except the "autostrada" are full of holes and bad construction asphalt.... so with the 17" it's a problem...
Please inform me with spring lb for the coilovers front and rear and also which extra work i have to do to the rear to fit them and i want to inform you that the car is for road use and hope to make some trackdays...
thanks
A. GAZ coilovers
B. AVO coilovers
thanks
Personally having driven the roads in Italy, I'd go for new Koni's with Chassis Dynamic springs std ride height, even with the koni set on max still nice and comfy.
