Stage 3 Question
Stage 3 Question
Hi,
At Stage 3 with a T34 is it always the case to go to grey injectors as well or is going with 803's normal practice or will these be on the limit?
Also with T34 is 2WD intercooler ok, Ive heard different answers, the latest saying that the standard intercooler is fine?
Also if you have a stage 3 chip does this mean it is mapped for green or grey injectors I guess it is dependant on what it's been mapped for?
Kind regards,
Martin.
Kind regards,
Martin.
Passion for Fords!
all of your questions are software dependant tbh,
the greens can fuel up to around 350bhp, anymore than that you need more fuel..
the intercooler can be ok, the only limiting factor of them is charge temp...if your charge temps go to high the ecu will retard ign and you will lose power, so you need to measure charge temp to determine if yours is ok...
any chip can be speced to run any injectors, so you need to ask whoever wrote the softeware what it should run on
As above but injectors can vary a lot, my 803's were at 80% at 300bhp, so don't assume all will be ok, saying that I have seen a set at 377bhp, but not sure on the pressure.
That's not at all the reason for the existence of blues.
It just happens to be good luck/fortune, a boggo std sapphy would/will run perfectly on greys, if mapped on greys.
a lot better than maxing 803s out and a nice injector to map to
Puller of the Wrench
Some guys on turboford.org claim the injector pulsewidth at higher duty cycles are better handled by siemens. You can max them with a better safety net apparently.
Notice there has been yet again no PROOF, just because msd and others etc sell them does not mean they are better, hey hang on maybe if the bosch aren't made any more that might be the reason they sell them and the same reason they are suddenly "the best".
So Jtech are YOU suggesting that everybody changes their injectors now just because they are more modern ?, even though they will have followed the advice at the time, on a car running perfectly well ?
Or does this yet again show a limitation of the std ecu ?
Are you sugesting no car can be mapped on greys properly even with lowish cossie bhp ?
The end result is what counts, not what a machine of any sort says is correct, the RESULT will speak for itself.
And yet again despite some people losing thier dummies there still is no PROOF.
I'm quite reasonable, show me proof and I will be ther first to say yes they are better, I won't hold my breath though.
This is totally pointless unless back to back testing is done.
Passion for Fords!
im not suggesting anything im asking a question....
do YOU think bosch would change the design of them if they were made today?
as for your comments, well surely this is a similar situation to YOU advising everyone to change ecus because they are old on almost every post of yours i read?
stuhas asked you to prove several things on various threads on here about ecus, and you have never replied with any proof at all....do you want me to find the threads for you so you can supply some?
well tbh i've never done any back to back testing or anything like that
but all the big tuners are now saying that the blacks are better for fueling low down and have a better spray pattern, i dont have the facility's to check any of these things so i've got to believe what i hear,
to me it just makes sence that injectors have evolved and the more modern seimens are gonna be better than the bosch 1's that were around 20 odd years ago
Not getting involved in this argument but when I went to speak to Tony he advised for what I wanted,to use 55lb Siemens blacks over geys as new technology.Surely there must be something in it if most of the major tuners are advising this.I was aiming for 400bhp.
so..
greens are good for stage 3 .. anything over that then siemens are supposedly more controlable. or is that easier to use ... hmmmmmm
and anyone who thinks a normal 2wd can cool air on stage 3 has never fitted a bigger intercooler.. the difference is quite notiable
after listening to many views then i would go siemens ver greys, if i ever had the need .... oh and what about costs ?
they are more expensive; but i imported mine from the US
http://www.fiveomotorsport.com/
actually i bought 8 injectors; sold 4 on ebay and kept 4 for myself; the 4 i sold almost covered the cost of my own. easy
Mc5506
05-10-2015 09:57 PM
