fuel pump 044
05-08-2008, 07:01 PM
fuel pump 044
just bought a 2wd saph and also a grp a 044 fuel pump is this a straigh swap or do i need to cut fuel pipes cheers for any help
05-08-2008, 07:35 PM
Straight swap if you get the fitment aswell m8.
05-08-2008, 08:08 PM
you will feed a 044 pump adapter for the pump to accept the fuel line from tank
one of these; if you send costina a message on here he's got loads
05-08-2008, 08:41 PM
already came with that fitting was just wondering about the other end cheers
05-08-2008, 08:47 PM
Quote:
Originally Posted by
cossie0_4
straight fit then mate
05-08-2008, 09:16 PM
As said m8 its a straight swap, some new copper washers for the banjo wouldnt hurt.
Steve
05-08-2008, 09:31 PM
Thanks Everybody For Your Help
06-08-2008, 09:19 AM
You also need to change the electrical connections to ring terminals as the original fittings won't go on to the 044 pump.
06-08-2008, 09:20 AM
Paul_RS
well said! - i forgot about that bit!
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
tib2220
14-09-2015 12:33 PM
