oil pressure switch
were is the oil pressure switch on my engine (2wd 1987)?
i want to change as the old one is knackered! many thanks |
on the left side of the engine, right between the starter and the inlet :)
find the turbo oil return(silver braided hose)and follow it down to the side of the block,it gopes into a big hex shaped fitting,on top of this out of sight is the switch,i changed mine as it was pissing out oil,cost less than half an hour to do and cost less than a fiver :top: ,tip.put the light under the car to see,use an adjustable spanner to unscrew it,set the jaws on the new switch before trying to undo the old switch and use your left hand to screw it out,much easier!good luck.
Some nice piccies there cosworth bassie!!
tabetha |
Thanks mate :D
Nice place to live too, been there many times to HILEGOM, and Amsterdam!!
tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
