What hardware am I missing (3 Dr transmission) ...
Was under my car and found that a bolt was missing from the front of the transmission bellhousing (RH side, opposite to where the starter bolts on) ...
https://i156.photobucket.com/albums/...00743Small.jpg I went and grabbed a spare bolt and nylok nut then I relised the hole is tapered (or threaded ... hard to see) so I couldn't clamp it together :wall: Has anyone got a photo or specification of the bolt ? :? (FINIS would be even better ;) ) |
from memory, thats just an M6 hole (takes a bolt with 10mm across the flats) to hold the sandwich plate in place that you can see in the picture that stops shit going in to the bellhousing/clutch
It is threaded, my car had the small bolt head sheared off, so had to drill and retap for a new larger bolt.
All its doing is holding the corner of the cover plate so us a thinner bolt and nut. |
Yup - as said - it also helps to line it all up of course ;-)
© 2024 MH Sub I, LLC dba Internet Brands
