Head bolt Trq settings?
For Dan off here as the puffs gone to bed as hes had to much shandy.
Whats the Trq settings for standard 2wd head bolts? |
Shandy drinking southern poofter :gay:
Here you go Dan ;) Firstly lightly oil bolt thread and underside of bolt head. Then tighten as follows. Stage 1: 20-25Nm Stage 2: 45-50Nm Stage 3: Turn thru 180 degrees (they will squeal like Trev getting his wallet out) |
Do whatever stage you like(as there are several) but finish at 120lb ft, as said LIGHTLY oil bolts/studs.
Now make a cuppa and leave at least 1 hour, then redo and you will find they are LOOSE, as the gasket partuicularly if FIBROUS ie group a will shrink a tad, if this retorque is not done it will not last. tabetha |
Cheers people, and for information only I aint been drinking! :blabla:
Thanks :top: |
© 2024 MH Sub I, LLC dba Internet Brands
