What oils in gearbox, axle etc
What spec oils should I put in my 4x4 Cossie, like the gearbox, transfer case, rear axle and front axle. From what I believe the rear axle cannot have ordinary hypoid oil as it has a LSD and should have special fluid. Can anyone help as it's going in tomorrow for a complete fluid change.
Thanks |
Rear diff oil MUST be LSD compliant oil, I use 75/W90.
As to the others not 100% sure, will look through one of my books later and repost for you. tabetha |
fully synthetic 75/90 in all 4x4 drivetrain components :top:
yes everything on the 4x4, front diff, gearbox,transfer box, rear diff.
just make sure its FULLY synthetic not cheap semi shite :cry: |
© 2024 MH Sub I, LLC dba Internet Brands
