Oil filter from Ford dealer or eBay - cheapest?
On eBay cheapest is £6.25 delivered - am I better going to Fords?
Matt lewis.
Who where?
I get mine from Ford, think it was about £3 for my last one, i did get a bit of discount though :)
Originally Posted by KSA-Cossie
http://stores.ebay.co.uk/Matt-Lewis-Racing :top:
Anyway, is it the tall filter or the short one on a 4x4 Cossie or can it take either? |
tall one :)
MATT LEWIS 01922 692424.
tabetha |
Now I've been told that the short filter is for the 4x4!
Long one is for 4x4 .
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHH HHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!! :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall:
Ok, so it's DEFINITELY the long one for my 1991 H plate 4x4 Sapphire Cos then??? Champion C102 was the long one I bought originally, was told today that no I needed the short one, so I exchanged it for a short one... |
You need the long one for a 4x4 because it doesn't have the oil cooler thingymajob the 2wd cossie has, which prevents a long one being used on the 2wd.
as above long one!and just go to fords i do cheaper then u think :top: and get a new sump plug/washer as well :clap:
Put sealant on the sump plug threads and it stops all the drips too.
tabetha |
Ok, so it's DEFINITELY the long one for my 1991 H plate 4x4 Sapphire Cos then??? Champion C102 was the long one I bought originally, was told today that no I needed the short one, so I exchanged it for a short one... either long or short will be fine.it is on mine anyway :top: |
If you had cut open a BRAND NEW EFL 298(cos 2wd) filter as I did, you might think twice about using them, I certainly will try to find a decent alternative from now on!!
tabetha |
Why is that?
Very small filter media area, and rust inside the brand new filter.
This filter had sat in my garage for a couple of weeks, in a SEALED UP FOOD BAG(freezer bag), as I put things in these to stop dust/grit etc getting to them, so had never got wet. tabetha |
So I'm dying to know, why did you cut the filter open?
Just to see what they were like internally, not sure I wanted to know as used to have faith in OE filters, not Ford ones anymore I don't!!
The one I cut open had been POSSIBLY contaminated, with iron filings, as had a bit of a mishap making some thermite!! tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
